Page 8 of 15
Re: OctaneRender® for ArchiCAD 2.10 [TEST]
Posted: Tue Oct 07, 2014 11:50 am
by rappet
face_off wrote:...
- You can now select multiple ArchiCAD objects and paste copied proxy setting to all those objects with a single "Paste" button click. USE WITH CAUTION....
Super Chill Paul, thanx
And sorry, I won't use with caution, I'll eat it raw
Posted: Wed Oct 08, 2014 11:08 am
by rappet
Hi Paul,
The copy-paste of proxy settings to multiple Archicad objects works perfectly.
I did not realize that the rotation of the Archicad objects are projected on the proxy!!! Superfantastic
greetz,
Posted: Wed Oct 08, 2014 11:13 am
by rappet
Hi Paul,
"save all renderpasses" seems to save only as exr, and not as png, even while in configuration Image Save Format is set to png?
greetz,
Posted: Wed Oct 08, 2014 12:32 pm
by face_off
That is correct Jeroen. PNG does not support the layer system that EXR does that is needed for saving all the render passes to a single file.
Re: OctaneRender® for ArchiCAD 2.11.1 [TEST]
Posted: Sat Oct 11, 2014 1:06 am
by face_off
2.11.1.20
- Compiled against Octane 2.11.1
- Added Highlight Compression to the Imager settings (see Standalone release notes for details)
- Changes to render passes as per Octane Standalone
- Added additional Color Correction node pins (see Standalone release notes for details)
- Added additional kernel pin Static Noise (see Standalone release notes for details)
NOTE: The first time you run the 2.11.1 plugin you will give a Cuda error "Failed to load preferences from "C:\Users\....". Pls ignore this error.
Posted: Sat Oct 11, 2014 2:47 am
by face_off
2.11.1.21
- Fixed issue where changing a disconnected texture pin to Image may default the image name to a corrupt text string
- IMPORTANT: AC18 - Fixed issue where ALL materials were being considered to be GDL materials, and therefore the plugin was removing all material name characters after the first space
Posted: Fri Oct 17, 2014 2:53 am
by face_off
I have refreshed the installer at the top of this thread with:
2.11.1.22
- Added new 2.11.1 Noise texture node
- Fixed issue where after rendering with the Photorenderer when the Octane Viewport is open, the Viewport render did not restart after closing the Photorenderer
- Added "Report on all Proxies" option from the Materials tab menu. It lists the ID for each proxy host Object used in the scene. This ID can be used to select the host Object via the "Find and Select" screen, putting the ID as the IFC Property "Name"
- Fixed issue where "Save Rendertarget as Default" was not working if the current rendertarget had been saved to a View
- Stopped the "Texture" node being transferred when changing the Environment node from Texture Environment to Daylight (and vise-versa)
- Fixed AC16 error being displayed when caching materials
- Fixed issue where the resolution was being lost if changing saved view rendertargets when Resolution Lock enabled and "Scene Refresh on View Change:" was enabled
Posted: Fri Oct 17, 2014 6:25 am
by face_off
There is a problem with the new Noise node in the above release. I will post a fix in the next 24hrs.
Posted: Mon Oct 20, 2014 2:59 am
by face_off
2.11.1.23
- Fixed issue where Noise Type could not be changed for the new Noise node
Posted: Wed Oct 22, 2014 8:43 am
by rappet
Thanx again Paul,
This would be a nice addition:
i.e. I select 12 objects in my scene and "re-convert selected materials from Archicad"\
instead of having to do it 12 times one by one.
cheers, Jeroen
