Re: OctaneRender® for 3ds max® v1.0 beta 2.58c[CURRENT]
Posted: Mon May 14, 2012 7:11 am
kepler update any news?
regards
nacho
regards
nacho
Community Forums for OTOY Customers
https://render.otoy.com/forum/
We work on it. For some reason render speed for this GPU is much lower than expected.nacho wrote:kepler update any news?
regards
nacho
it works,Karba wrote:Hm, just have checked. It works as it should.gabrielefx wrote:***ISSUE***
Octane for Max lacks the possibility to save in exr or hdr 16-32bit using octane camera.
If I deactivate tonemapping but I use an octane camera the exr or hdr saved file will have 8 bit color depth and will maintain the tonemapping.
Impossible to use this render for professional color correction.
What did you do to get the issue?
I have fixed it already. Wait for a new release.gabrielefx wrote:@Karba:
Octane for Max suffer of the old annoying bug at big resolutions.
If I launch a render at 4000x3000 pixels (using the Max frame buffer) and I try to stop it Max crashes.
I use all my 4 GTX580.
Please Karba, could you check it?
I think you need a workstation with 4 GTX to understand the problem.
Thank you Karba,Karba wrote:I have fixed it already. Wait for a new release.gabrielefx wrote:@Karba:
At what stage of render does it happen?gabrielefx wrote: I found another bug.
I'm rendering several 4000x3000 pixels images and randomly Octane for Max crashes the gpu. On the previous release never happened.
It doesn't happen only on gpu 1 but can happen on gpu 2, 3 or 4
It happens randomly.
Hi Crikocriko3d wrote:Hi everybody!, one question... is this version ready to work with 2013?, thanx!
It happened in one room of a big apartment model. I restarted the workstation and everything was fine again.Karba wrote:At what stage of render does it happen?gabrielefx wrote: I found another bug.
