Page 7 of 8
Re: Cinema4D version 2020.2.5-R3 (Latest stable) 16.09.2021
Posted: Thu Sep 23, 2021 2:01 pm
by SSmolak
aoktar wrote:This is not directly related to plugin part. Also not sure it's a bug in Octane core. Even not sure it's a bug or not. Maybe about the profile you choose in OCIO. Best answer will come from @Karl.
Generally all 32bit renders that come from OCIO looks like that. No matter what exactly OCIO profile is chosen.
Posted: Fri Sep 24, 2021 2:39 pm
by BCres
SSmolak wrote:From PV. If color space is set to main ACES it works fine - full 32bit output but if color space is chosen from OCIO list it saving as 8bit.
Images are after 32bit exposure correction in external software.
From SSmolak's second shot in this post from the previous page, the OCIO is Rec 709. That may be the problem. Rec 709 is usually defined as an 8bit color space with values of 16-235. I use the OCIO setting in the picture and it matches the ACESCg setting as well. Notice my OCIO/ACES selection. Anyhow, this is what works for me.
Posted: Sat Sep 25, 2021 6:06 pm
by SSmolak
BCres wrote:From SSmolak's second shot in this post from the previous page, the OCIO is Rec 709. That may be the problem. Rec 709 is usually defined as an 8bit color space with values of 16-235. I use the OCIO setting in the picture and it matches the ACESCg setting as well. Notice my OCIO/ACES selection. Anyhow, this is what works for me.
But that problem is with EVERY OCIO profile other than standard ACES even Filmic one from https://sobotka.github.io/filmic-blender. They all give 8bit output just like Octane while using Camera Image corrections.
Posted: Sat Sep 25, 2021 7:14 pm
by BCres
I apologize SSmolak, I see the problem you're having is with ACES configurations other than the ACES official (which is what I use.) My mistake. It was your example using REC709 that threw me.
Posted: Sun Sep 26, 2021 6:17 pm
by zoppo
Just a small suggestion: would it be possible to set EXR(Octane) as standard format in the render passes tab?
I always use this (cryptomatte!) but sometimes I forget to switch from EXR and then have to re-render.
Posted: Sun Sep 26, 2021 9:21 pm
by aoktar
zoppo wrote:Just a small suggestion: would it be possible to set EXR(Octane) as standard format in the render passes tab?
Yes if others agree with this!
Posted: Mon Sep 27, 2021 7:58 am
by forward
I am for this request as well!
Posted: Tue Sep 28, 2021 7:39 pm
by thanulee
+1
Posted: Wed Sep 29, 2021 6:04 pm
by Kalua
Why not... any disadvantages I am not aware?
Posted: Fri Oct 08, 2021 7:36 pm
by Delizade
Hello,
1) add a material(reference material) and use a RGB Spectrum note do it then link it to the Diffuse channel. (Lock its property window)
2) add second material(main material). add a RefShader and drag source material's RGB Spectrum link to its link value.
3) assign main material to an object, run Live Viewer
4) change source material's RGB color node value.
Live viewer is not updated. User has to refresh it to see ref shader's updated value.
