Page 7 of 7
Re: OctaneRender™ for Blender 2.06 - 6.4 Win [CURRENT]
Posted: Tue Nov 11, 2014 5:29 pm
by afecelis
Hi Szymon, I followed your instructions but it didn't work
Here's my material node setup. It's also showing the white background.
Posted: Tue Nov 11, 2014 7:39 pm
by Elonius
Hi Jimstar I think the render server is still crashing on me while trying to render my character. Nothing has happened for about 15 minutes. The scene works fine in standalone. Here is a photo to show what is happening. I cannot upload the file because it is 830 MB. I could not find the dump files in that folder as you instructed. Do you think this is still a memory problem? I am only using the gtx titan in this case. When I hover over the render server icon in the bottom right corner it goes away.
Pc specs:
i7 3770k
16GB
Titan Black
GTX 680
Posted: Tue Nov 11, 2014 8:04 pm
by JimStar
Elonius wrote:Hi Jimstar I think the render server is still crashing on me while trying to render my character. Nothing has happened for about 15 minutes. The scene works fine in standalone. Here is a photo to show what is happening. I cannot upload the file because it is 830 MB. I could not find the dump files in that folder as you instructed. Do you think this is still a memory problem? I am only using the gtx titan in this case. When I hover over the render server icon in the bottom right corner it goes away.
It's hard to guess the reason not having the scene... Do your scene have a big amount of "global" meshes? Does it never render this frame or sometimes it renders sometimes it crashes? Have you tried to refresh the NVIDIA drivers?
Posted: Tue Nov 11, 2014 10:52 pm
by kubicki3d
Afecelis, you need to tick "Premultiplied alpha" in the camera settings.
- Premultipied alpha
Your glass will look ok only when seen through the camera, like in the screenshot below.
- Glossy shader for architectural glass
As you can see I went a bit higher with opacity. You can also play with colour, index and specular for example to achieve tinted glass.
Cheers, Szymon
Re: OctaneRender™ for Blender 2.06 - 6.4 Win [OBSOLETE]
Posted: Wed Nov 12, 2014 4:05 am
by JimStar
