Page 6 of 34
Re: Cinema4D version 2020.1 (Stable release) 27.04.2020
Posted: Tue Apr 28, 2020 9:22 pm
by aoktar
Broccoli wrote:aoktar wrote:RTX performance is not directly related with plugin, it's up to core. Also there's not a rule as every scene will show a performance boost. My advice for you trying different scenes and also provide some scenes to us, I'll ping core team to invistage for possible improvements.
Here is a test scene that i made in c4d and sent to standalone, i get no RTX boost at all in standalone or c4d, its actually slower with rtx reporting a .88 speedboost using RTX
better to send orbx for next time, anyway I can see content of scene. It's very simple one, RTX shows mostly the muscles with dense scenes. For example vegetation scenes, pathtrace heavy scenes.
Posted: Tue Apr 28, 2020 9:24 pm
by aoktar
iamcyclo wrote:
Yes all old files and only the R20 build is left in folder. Followed the instructions.
So another sight, you forgot another install in other plugin search path. It makes conflicts. Or installing to unexpected location.
Posted: Tue Apr 28, 2020 9:52 pm
by Broccoli
aoktar wrote:Broccoli wrote:aoktar wrote:RTX performance is not directly related with plugin, it's up to core. Also there's not a rule as every scene will show a performance boost. My advice for you trying different scenes and also provide some scenes to us, I'll ping core team to invistage for possible improvements.
Good to know, I'll try loading and making more complex scenes and see if I still have no boosting. Does anyone have a scene they can share that does benefit from rtx being on, that way I can eliminate any question of if it's just my scenes not benefiting.
Posted: Wed Apr 29, 2020 12:30 am
by iamcyclo
I only have one install of cinema, I have checked both folders there are no other instances of octane. Like I have said, I am very aware of how to install the plugin because if I downgrade to an old version it works fine so I am very aware of how to install this plug.
Posted: Wed Apr 29, 2020 4:29 am
by mr_d_wilks
is there a way i can make sure that RTX will be enabled when rendering via deadline / cinema4dbatch ?
i see the preferences_v2 file in %appdata%\OctaneRender\{374207c25da13b52bc0a2f110ad946e3}\ but ideally this setting can be set from within the cinema 4d scene file. is there any way to do this?
Posted: Wed Apr 29, 2020 7:00 am
by martinzip
Dear Ahmet
installation of RC4 works fine! So there must have happened something in the last step.
Maybe it is the same in windows installations?
kind regards
Martin
Posted: Wed Apr 29, 2020 8:27 am
by nejck
You can fire up one of the heavier scenes that come with c4d, delete all the materials and place a light source in there. That should net you a sizeable increase, if it indeed works
RTX appears to be most beneficial when you have a lot of objects or even better a lot of dense objects. If you create a tree field you should see improvements of upwards of 2x, sometimes even 5x.
Still, keep in mind that it mainly helps with the raytracing part. Put a single object in there with a crap ton of sophisticated shaders and you won't see a difference at all.
From some of my production scenes which are predominantly interior like scenes I've seen boosts from 20% to about 2x.
Posted: Wed Apr 29, 2020 9:50 am
by divasoft
Hi. Ahmet you released 2020.1 version, but i can't run render with my slave node.
Standalone works well. Can you update version? My commercial project production too much slow now.
Posted: Wed Apr 29, 2020 10:02 am
by paypal-ict
Anyone found a proper way to work with ACES / OCIO? I found this new icon in the live viewer, which you can toggle:
LDR 8-bit
HDR
HDR Linear
ACES
And in the rendersettings in Cinema4D there's a new option under Render buffertype: Linear ACES 2065-1
And in multipass options you can also set the Tonemap type to: Linear ACES 2065-1
But how can I show the Live Viewer as usual but use the ACEScg workflow? I tried applying a LUT in the camera imager wile LiveViewer is set to ACES-mode, but nothing happens.
Posted: Wed Apr 29, 2020 11:02 am
by aoktar
martinzip wrote:Dear Ahmet
kind regards
Martin
OSX R20 build is wrong, putted older version. I'll fix it with next build, you can still use RC4 until that.
