Page 6 of 10
Re: Cinema 4D version 2020.1-XB1-Test2 (EXPERIMENTAL) 10.12.2019
Posted: Thu Dec 12, 2019 6:04 pm
by aoktar
nejck wrote:Funny thing, from some quick testing on a heavy scene I was working with the Multi-Core option ON it all really slowed down shader generation / refreshes. Any change to a shader in a heavy scene caused a 1 second UI freeze throughout C4D. My CPUs are 2x 2696v3 Xeons.
All that said, that was in the 2019 version, haven't tested it in the latest 2020 which by the way looks like a really awesome update to me!
Can't wait to see the multi-threading in action, such an awesome surprise!
If so try to don't use all cores. Leave a few cores is reserved for other operations. Also do not use multi-core for Live Viewer option and use render priority for gpus.
Posted: Thu Dec 12, 2019 10:25 pm
by Raoul
Anything like a rough estimate on when we can expect to see a an OSX version of this?
looking forward to testing it out.
many thanks Ahmet
Posted: Fri Dec 13, 2019 12:18 am
by SSmolak
When Out Of Core is enabled and in usage, every render after successful last render fails. Reset render data helps to make next render fine.
error : failed to allocate device memory on two cards. NV Link ON but memory pooling not work of course. RTX OFF, multi-thread for materials ON
EDIT : This is caused by multi-thread for materials because when this setting is OFF every render starts fine without the need of reseting.
Posted: Fri Dec 13, 2019 9:39 am
by nejck
Interesting. You mean through Windows affinity settings or through C4D directly?
Posted: Fri Dec 13, 2019 11:15 am
by aoktar
SSmolak wrote:When Out Of Core is enabled and in usage, every render after successful last render fails. Reset render data helps to make next render fine.
I'm testing with all cases, no crash with that. Are you using RTX?
Posted: Fri Dec 13, 2019 11:21 am
by SSmolak
It doesn't crash but quit from rendering with error message or freeze. Reseting render by Octane button helps and after that next render go fine. It occur only when Out Of Core is in usage and multithreaded materials are on. RTX off. I mean full rendering not Live View window. I can provide test scene.
Posted: Fri Dec 13, 2019 12:22 pm
by aoktar
SSmolak wrote: It doesn't crash but quit from rendering with error message or freeze. Reseting render by Octane button helps and after that next render go fine. It occur only when Out Of Core is in usage and multithreaded materials are on. RTX off. I mean full rendering not Live View window. I can provide test scene.
Send me your scene if it's specific one
Posted: Fri Dec 13, 2019 9:42 pm
by divasoft
Ahmet, LUT strength not affected now.
Posted: Sat Dec 14, 2019 10:32 am
by VVG
divasoft wrote:Ahmet, LUT strength not affected now.
all ok
Posted: Tue Dec 17, 2019 10:29 am
by wrapthereal66
thanks you !! :)
just one thing, for me the octane fog volume don't work ! vdb yes, fog nope !
