Page 6 of 16
Re: Version 2.16.1 test2
Posted: Mon Jan 05, 2015 12:25 pm
by aoktar
Hi sodapop66,
can you check active project's "tex" folder to see images doesn't extracted? Also can you send me a few your *.orbx package to check it? What's your OS and language of OS? Also can you try with a "saved scene"?
Anyone else see this problem?
Posted: Mon Jan 05, 2015 1:26 pm
by sodapop66
Hi Aoktar
i've found the problem :P
if i open blank new c4d, indeed i have lot of missing textures :cry:
but if i open any saved c4d files, every materials from local or user live db is correct :geek:
running on windows 8.1 pro french and C4D french language
Posted: Mon Jan 05, 2015 1:32 pm
by aoktar
sodapop66 wrote:Hi Aoktar
ok, we detected same on some user. Why this happens? Octane needs to copy the files a folder. If we have a scene, it copies to scene's tex folder, otherwise uses "Documents/tex" folder. There should be a problem about acces the files.
Posted: Mon Jan 05, 2015 6:51 pm
by aoktar
i have changed some code for livedb issues. material preview issue still here but others should be fixed. please see here
http://render.otoy.com/customerdownload ... t3-win.zip
Posted: Mon Jan 05, 2015 8:50 pm
by sodapop66
thanks for your help Aoktar but i'm sorry , i've just checked last test3 and it's worse
Now i've missing textures with saved files or copy & paste materials between open file, not only with blank c4d start.
and some material doesn't load in the materials c4d windows
need to come back to test2
**nice improvement with popup menu to display the size of thumbnail.
Posted: Mon Jan 05, 2015 8:54 pm
by aoktar
sodapop66 wrote:thanks for your help Aoktar but i'm sorry , i've just checked last test3 and it's worse
why worst? there is not any implementation for copy/paste between scenes. All should be same. You have to copy tex folder if you copy paste materials.
Posted: Tue Jan 06, 2015 1:07 pm
by arsen
sorry if already posted, but in Rednder tab Display pass doesnt change passes.. only if resend&restart render
Posted: Tue Jan 06, 2015 1:14 pm
by aoktar
arsen wrote:sorry if already posted, but in Rednder tab Display pass doesnt change passes.. only if resend&restart render
what do you mean exactly?
Posted: Tue Jan 06, 2015 1:57 pm
by arsen
it works in 2.12
Posted: Tue Jan 06, 2015 6:07 pm
by aoktar
it works in 2.12
fixed
