Page 6 of 28
Re: OctaneRender® for Poser (Windows) 2.0 [TEST]
Posted: Mon Jun 23, 2014 10:49 am
by face_off
2.01.0.18
- Compiled against Octane 2.01
- Fixed python error "ValueError: Error in SetOctaneApiNodeValue - null Octane node for node maxsamples, node type = int"
Octane 2.01 removes the previous texturemap number limits - which is fantastic news for Poser users, since we were often hitting these limits when there were many figures/props in the scene.
Posted: Mon Jun 23, 2014 11:05 am
by samhal
face_off wrote:I have refreshed the installers at the top of this thread with:
2.01.0.18
YAY!!!
Re: OctaneRender® for Poser (Windows) 2.01 [TEST]
Posted: Mon Jun 23, 2014 11:47 am
by Zay
It looks like it works
Posted: Mon Jun 23, 2014 11:49 am
by Zay
StoneMasons Bigcity, AbandonedCity 1 and AbandonedCity 2 crash Poser (octane.dll).
Posted: Mon Jun 23, 2014 12:40 pm
by face_off
I had a crash on a very large Modo scene - and I wondered if perhaps it was due to running out of VRAM. Could that be happening to you? What does the scene texturemap Poser script report as the total VRAM required for that scene?
Posted: Mon Jun 23, 2014 12:41 pm
by face_off
Number of HDR textures looks wrong in that screenshot. I will check that out.
Posted: Mon Jun 23, 2014 1:06 pm
by Zay
For AbandonedCity 1 :
Total Num Texture Maps (rgb) : 50
Total Num Bump/Trans Maps (grayscale) : 48
Total Memory Required for Textures : 609.9MB (assumes only LDR textures)
DEBUG:root:Opening Viewport - setting rendertarget
And then it crashes.
It also crash in v.2.0.9.17
Posted: Mon Jun 23, 2014 1:12 pm
by RGUS
face_off wrote:Did all this and bugger me days... it works fine with standalone versions... but only works up until poser plug-in version 1.54... everything after that turns to custard.
Obviously something I'm doing wrong since no else is experiencing any similar problems... think I should go back to firefly and stop annoying people.
Sounds like a plugin issue in that case. Are you able to send me a pz3 with the head and hair geometry and the transmap?
Also, have you tried a complete uninstall and re-install of the latest version of the plugin?
And did you try the "scale" workaround?
Been trying top send this for the last couple of days... but obviously the ZIP file is too big for the site servers to accept, just hangs ans sits for ages after the submit button pressed.
Posted: Mon Jun 23, 2014 1:14 pm
by RGUS
2.01.0.18
Do you mean Octane 2.01 Standalone or Octane Poser Plugin 2.01... "removes the previous texturemap number limits"... ?
Posted: Mon Jun 23, 2014 1:15 pm
by face_off
Not a memory issue then. Could it be that scene uses a displacement map and the displacement amount is too high? Are you using Octane Subd for any props? (there is a known issue with certain props with the OpenSubDiv library). If you can't work it out, pls send me the scene and I'll take a look.
