Page 6 of 11
Re: OctaneRender® for 3ds max® v1.31[Test]
Posted: Sat Mar 01, 2014 1:22 am
by merid888
directlight and diffuse, AO 4, two octane lights, one front another behind camera, the background is a simple image, 1000 maxsamples
Posted: Sat Mar 01, 2014 2:58 am
by Karba
merid888 wrote:directlight and diffuse, AO 4, two octane lights, one front another behind camera, the background is a simple image, 1000 maxsamples
What is your specular depth?
Posted: Sat Mar 01, 2014 9:15 am
by gabrielefx
Hi Karba,
Octane has a serious issue or limitation!
Can't render a scene with many different ies. I think that Octane can't handle too many photometric datas.
I created a scene with about 20 different ies photometric lights and instanced them. In the scene I have about 500 or more lights.
Unfortunately I can't render all of them because some photometric light distributions disappear and they are rendered as spherical lights.
I think you can explain this issue. Gpu limitation?
regards
(I'm using the 1.18 because is faster and the latest release does't convert all textures, ies, hdrs, etc.)
Posted: Sat Mar 01, 2014 9:33 am
by Karba
gabrielefx wrote:Hi Karba,
regards
Please check the texture statistic. Every ies texture takes one gray scale 16bit texture.
Posted: Sun Mar 02, 2014 12:33 am
by merid888
specular depth is 8,glossydepth is 4, aodist 4 and diffusedepth 4
Posted: Sun Mar 02, 2014 4:22 am
by Karba
merid888 wrote:specular depth is 8,glossydepth is 4, aodist 4 and diffusedepth 4
Try to increase glossy depth to 8 or more
Posted: Sun Mar 02, 2014 5:43 am
by Hamed.Mojtabavi
hi
i setup this version of plugin but i have any more crash
my system is : 8 g ram M.B intel dp45sg and i have 2 gpu a:msi 580 oc b:pny 580
when i render animation after a lot of frame 3ds max2013 closed .
Posted: Sun Mar 02, 2014 3:33 pm
by gabrielefx
regards
Hi Karba,
are you joking????
Can I use only 10 photometric is files with my Titans????
With iray I can use any number of ies photometric I want.
Please find a solution for this issue. Thank you.
Posted: Sun Mar 02, 2014 7:00 pm
by Karba
gabrielefx wrote:
Karba wrote: Please check the texture statistic. Every ies texture takes one gray scale 16bit texture.
Hi Karba,
are you joking????
Did you check the texture statistic? What does it show?
Posted: Thu Mar 06, 2014 11:12 pm
by acc24ex
Hey Karba, could you please share some info on how to change to different kernels via maxscript, like those "actionMan.executeAction" values - I just want to switch from say PT kernel to Info kernel, and render material ID - and want to make a button of it, cause I'm doing this now a lot,
- I'd just like to implement those kernel buttons into a script for faster switching, when you make a scene, and change textures, this is mostly what I'm doing anyway, switching textures, cameras and kernels for different versions
