Re: OctaneRender® for 3ds max® v1.0 RC1a[Test]
Posted: Wed Oct 31, 2012 8:46 am
Sorry for dumb question but how I can get alpha channel from specular material on render?
Like this
Like this
Community Forums for OTOY Customers
https://render.otoy.com/forum/
Karba wrote:Do you have just black screen, or checker?freelancah wrote:I was testing if I can reduce my Gforce 480 GTX memory load by installing a radeon card to my system, mostly to run windows and other tasks. Octane 3D Max plugin is not working but the standalone is. Inside 3D max all I get is an empty black render with no geometry loaded. The render setup however recognizes the 480 as a CUDA device. Why is it that the standalone has no issues to render but the 3D Max plugin cant do anything?
freelancah wrote:Sorry meant to say checker. All the statistics on the screen indicated that nothing was loaded to the card.
Edit: Also using max 2013 and 480 gtx + radeon 6780. W7 too.
Do you use Radeon for display only?freelancah wrote:Karba wrote:Do you have just black screen, or checker?freelancah wrote:I was testing if I can reduce my Gforce 480 GTX memory load by installing a radeon card to my system, mostly to run windows and other tasks. Octane 3D Max plugin is not working but the standalone is. Inside 3D max all I get is an empty black render with no geometry loaded. The render setup however recognizes the 480 as a CUDA device. Why is it that the standalone has no issues to render but the 3D Max plugin cant do anything?freelancah wrote:Sorry meant to say checker. All the statistics on the screen indicated that nothing was loaded to the card.
I tested with Radeon 6870 and 5400. Both have the same issue, yet with both the standalone is working fine. Is this a bug or a feature of 3D max plugin? Anyway I'm planning to get a GTX 580 to run with pair with my 480 so it wont be an issue long. Anyway I just think that if this is in fact a reality with radeon cards I suggest putting it in writing somewhere before anyone wastes their money.
Can you show your GPU dialog in 3dsmax?freelancah wrote:Yeah, the intention was to reduce load from all my monitors and have some power to run other applications while the Gforce was rendering
Are you sure plugin see GTX480 when Radeon is installed?freelancah wrote:No I cant atm. I removed the cards since I have a deadline job that I have to finish before monday.. I can test after that probably.
Edit: Well actually I can, because it looks the same with or without the Radeon..Here it is. It looks like this with both cards, just doesn't seem to render.
Karba wrote:Are you sure plugin see GTX480 when Radeon is installed?freelancah wrote:No I cant atm. I removed the cards since I have a deadline job that I have to finish before monday.. I can test after that probably.
