Page 6 of 7
Re: NEW: Launching of OctaneRender™ for Maya®
Posted: Tue Aug 07, 2012 4:38 pm
by JimStar
RickToxik wrote:... I have some little issues but generally working good. ...
Please, report HERE about all issues - new versions are released very often, so if you will report, these issues have the chance to be fixed in one of next versions...
RickToxik wrote:I am quite happy, keep up the good work.
Thanks! Image
Posted: Wed Aug 08, 2012 4:09 pm
by ypolyz
Hi abreukers,
support of instances for Maya when is planned? Thank you
Posted: Wed Aug 08, 2012 6:01 pm
by RickToxik
petermax wrote:
Garrick wrote:I know this is off topic but when will Octane support displacement mapping?
just wondering why don't you use normal maps?
Normal map is a shading effect, displacement affects the geometry. I too would like to see octane support displacement.
Adding a displacement system in octane and an "octane proxy" node too would be very cool.
Posted: Thu Aug 09, 2012 4:45 am
by abreukers
ypolyz wrote:Hi abreukers,
soon ypolyz... can't put a date on that yet. instancing support has to be added and polished in the standalone edition first, this would be closely followed by the pilot plugin (max), and then finally the third party integrated plugins (maya, etc).
currently the standalone edition with instancing support is pretty much under construction, and what we see here this month (august 2012) are the previews of it...
Posted: Thu Sep 27, 2012 10:41 am
by juang3d
Does the maya plugin support the mia_material_x? (even if it converts it at render time).
Cheers.
Posted: Thu Sep 27, 2012 10:56 am
by JimStar
juang3d wrote:Does the maya plugin support the mia_material_x? (even if it converts it at render time).
Cheers.
I've answered HERE.;)
Posted: Thu Sep 27, 2012 11:14 am
by juang3d
Thanks JimStar.
Posted: Fri Sep 28, 2012 4:32 pm
by juang3d
Hi.
I have another question.
Can i use backburner to render with octane from maya?
Also, should i acquire a standalone license and a maya plugin license for every node in the farm?
To be more clear:
My main workstation = 1 standalon + 1 plugin, i launch a batch render to backburner from maya
node1 = 1 standalone + 1 plugin
or
or
node1 = no license needed at all.
Other question is, can i send a finished maya scene to Octane Standalone(including things like particles)?
and
Can i use backburner to make octane standalone render my animation?
Cheeers and thanks!
Posted: Fri Sep 28, 2012 5:26 pm
by JimStar
juang3d wrote:Can i use backburner to render with octane from maya?
Octane for Maya plugin works in both Maya's "batch render" mode and in "command" mode. Maya for Windows can't render in "batch render" mode over the network. But theoretically you can try to use the "command" mode to form the jobs for backburner (I don't have the info from users if somebody uses it such a way)...
juang3d wrote:Also, should i acquire a standalone license and a maya plugin license for every node in the farm?
Yes.
juang3d wrote:Other question is, can i send a finished maya scene to Octane Standalone(including things like particles)?
Octane for Maya plugin can export the scene to Octane's .ocs format. And this format to be opened by standalone requires the .obj file which should be exported by some another Maya's .obj-export plugin (if you have it installed).
But you should know that the Octane for Maya version with instances-particles support is in the test branch at the time. The stable version does not support the instances.
Re: Launching of OctaneRender™ for Maya®
Posted: Thu Nov 29, 2012 6:20 am
by Freyr
Hi guys. I`m thinking about buying octane for maya. How buggy is it nowadays? Can it render maya`s fluids/particles/ hairs ? Render layers, displacement map. What about material presets? (Wood, water, stone, glass, etc)
Why i can`t find demo on site?
