Page 31 of 55
Re: Version 2.02- test version - Update (01.07.14)
Posted: Wed Jul 02, 2014 6:11 pm
by shawnfrueh
I have discovered another problem with motion blur. When Vertex motion blur is enabled I sometimes get black polys. When I turn off Vertex and change it to Transform The issue is fixed.
Vertex on:
Transform On:
Posted: Wed Jul 02, 2014 6:59 pm
by aoktar
shawnfrueh wrote:I have discovered another problem with motion blur. When Vertex motion blur is enabled I sometimes get black polys. When I turn off Vertex and change it to Transform The issue is fixed.
Vertex on:
Transform On:
pls could you post your scene, for checking the issue?
Posted: Wed Jul 02, 2014 10:00 pm
by LFedit
Aoktar, awesome work on the 2.02 plug in, the advancements in the plug-in are amazing! Just wondering if there is any difference in using the Foreground and Background object in the live viewer. It was working in 1.5.2 and have been using it for compositing work very successfully. Can you check this, or anyone else confirm it's not working? Thanks again, awesome job!
Posted: Wed Jul 02, 2014 10:45 pm
by aoktar
LFedit wrote:Aoktar, awesome work on the 2.02 plug in, the advancements in the plug-in are amazing! Just wondering if there is any difference in using the Foreground and Background object in the live viewer. It was working in 1.5.2 and have been using it for compositing work very successfully. Can you check this, or anyone else confirm it's not working? Thanks again, awesome job!
Thanks i'm trying to make it better,
i have worked on back/fore. objects since 1.52. It should work on LV and picture viewer as usual with standart material. Standart material should have a image in diffuse channel.
Posted: Thu Jul 03, 2014 8:48 am
by tkkim
Hi, all!
Please help me.
How can I make slave machine with my mac(GTX580) in network rendering.
There is no _install_daemon.bat file in mac version.
Posted: Thu Jul 03, 2014 8:56 am
by bepeg4d
tkkim wrote:Hi, all!
Please help me.
hi,
the net rendering is managed by the standalone version. infact you don't need a separate plug-in licence for the slave but only a standalone licence.
In the osx standalone 2.02 installer you can find the install_demon and uninstall_demon scripts
ciao beppe
Posted: Thu Jul 03, 2014 9:12 am
by tkkim
bepeg4d wrote:tkkim wrote:Hi, all!
Please help me.
hi,
ciao beppe
Thank you so much!!!
I will try!
Posted: Thu Jul 03, 2014 10:00 am
by momade
in 2.02 as motion blur in enabled in the camera-tag, the blur is globally always activated. no matter which settings are used in octane object tag or octane render settings.
plus: the images seem identical in lifeviewer/pictureviewer, but upon saving the png from pictureviever is significantly darker.
c4d win r15
file IS attached
br.
mo
Posted: Thu Jul 03, 2014 1:40 pm
by tkkim
tkkim wrote:bepeg4d wrote:tkkim wrote:Hi, all!
Please help me.
hi,
ciao beppe
I will try!
Hi, bepeg4d
If I make slave machine, I have to buy another standalone account?
Posted: Thu Jul 03, 2014 3:53 pm
by bepeg4d
tkkim wrote:[Hi, bepeg4d
hi,
unfortunately yes, for now.
Otoy has already said that in the future the net licence scheme will be changed, probably with a properly slave version, but we don't know when will be
ciao beppe
