Page 4 of 7
Re: Version 3.08.2-R2.1 (latest stable) Displacement
Posted: Fri Jul 20, 2018 9:50 am
by martinzip
Dear Ahmet,
thank you very much for the great work you do!
I found a problem with the displacement. It seems that it does not recognize the the black color in the mapping mode...
When I use the Imagetexture as in the bump node I see only one bump which is correct, when I connect the same imagetexture to the displacement node I see tiles of the texture!
I can manipulate the size but it is not possible to stop the tiling...
kr from sunny cologne
Martin
Posted: Fri Jul 20, 2018 10:55 am
by bepeg4d
Hi Martin,
it's a known limitation of Octane Displacement.
You need to restrict with a polygon selection, or adapt the displacement map.
ciao Beppe
Posted: Sat Jul 21, 2018 9:49 pm
by Cheiser
Hello there.
If there is any option to add more Light Passes? Now we have Ambient, Sun and 8 light passes.
Can we have someday more Light Passes? Like Render Layer Mask (24)
Posted: Mon Jul 23, 2018 9:38 am
by bepeg4d
Hi Cheiser,
this kind of request is SDK related, not plugin related, and must be asked in the Standalone section, or even better in the Future Requests section of the Otoy site:
https://render.otoy.com/requests/
ciao Beppe
Posted: Mon Jul 23, 2018 12:34 pm
by David_S
since version 3.08.2-R2.1, I have «Invalid Version» in network rendering panel.
Slave is Windows 10, Octane 3.08.2
best regards
David
OSX 10.13.6
CUDA Driver Version: 396.64
GPU Driver Version: 387.10.10.10.40.105
Posted: Mon Jul 23, 2018 1:18 pm
by bepeg4d
Hi David,
everything is working as expected here:
Please, go to c4d menu Script/Console (Shift+F10) and share a complete screenshot of the panel.
What kind of messages do you see in the prompt window of the Slave?
ciao Beppe
Posted: Mon Jul 23, 2018 1:45 pm
by David_S
Hi Beppe,
I installed 3.07 and then again 3.08.2-R2.1. It's working now
Posted: Mon Jul 23, 2018 1:53 pm
by bepeg4d
Hi David,
great, happy to hear that the issue is solved
Happy Rendering,
ciao Beppe
Posted: Thu Jul 26, 2018 6:52 am
by stefano-dear
in this release the function "remove duplicated materials" doesn't work?
best regards
Stefano
Posted: Thu Jul 26, 2018 10:27 am
by Ron
stefano-dear wrote:Hi,
Same question here.
