Page 4 of 5
Re: OctaneRender™ for Blender 1.20.2 - 2.2 beta Win [CURRENT
Posted: Mon Oct 07, 2013 1:58 am
by JimStar
vinz wrote:Hi Jim,
A little question, now the liveDB is supported is there a way to import my own macro material inside blender? is there a place where the live db is cached on hard drive where i can put my ocm ?
i would like to convert my octane project for blender, but my project materials are too much complex for rebuilding everything in blender
So far it is impossible. A lot of work is needed to add the local database feature...
Posted: Mon Oct 07, 2013 2:02 am
by vinz
Good to know ! thanks for your answer Jim ...
Posted: Mon Oct 07, 2013 4:47 am
by JimStar
Ooops, I see the bug in RGB colors of materials taken from LiveDB.
Will be fixed in next version very soon.
Posted: Mon Oct 07, 2013 7:58 am
by matej
JimStar wrote:megacal wrote:Only 1 small request: could the default number of samples for Max/Preview be 100/200? (vs 16000/3000)
What do others think about it?
Personally I have never rendered anything to 16000 samples. While shading & lighting in the standalone I use 32 - 64 for preview. Id say 64 samples for preview, 1024 for finals
Posted: Mon Oct 07, 2013 8:16 am
by JimStar
matej wrote:Personally I have never rendered anything to 16000 samples. While shading & lighting in the standalone I use 32 - 64 for preview. Id say 64 samples for preview, 1024 for finals
I just can't understand why do you need to stop the preview render at all.
As I e.g. never change it from 16000, and it just gets better and better before I change something again... And it does not interfere with work, as the different card is used for display... But I'm not 3D-artist, so perhaps I do not see some other reasons for this...
Posted: Mon Oct 07, 2013 8:31 am
by matej
JimStar wrote:I just can't understand why do you need to stop the preview render at all.
There are no artistic reasons for this. I just don't like needlessly overtaxing the graphic card. When setting up materials / lights / camera, 64 samples will in most cases give you the same useful feedback as 16000, so running the card continuously is just a waste of power, imo. I also set up most of my shaders "blindly", ie. with the render paused, and only use the preview when fine-tuning parameters.
Posted: Mon Oct 07, 2013 11:19 am
by rattle-snake
Hey ! Yes i agree with you !
For me too, 200 samples are enough for a preview.
Also, is it possible to add a little "lock" radio button in order to keep the ratio while changing the render size ?
Final question : In order to hide the planes emitting the lights in my scene, i just put the opacity to 0 into the material settings.
It works but the problem is that these planes are still displaying the shadows of the others planes.
(I can put a picture, if it's not clear !)
Thanks a looot
Posted: Mon Oct 07, 2013 11:30 am
by matej
rattle-snake wrote:Final question : In order to hide the planes emitting the lights in my scene, i just put the opacity to 0 into the material settings.
The Portal shader is used for this functionality. Surfaces with this shader will be completely hidden
Posted: Mon Oct 07, 2013 6:56 pm
by JimStar
OK, so I make it 100/200?..
Posted: Mon Oct 07, 2013 7:50 pm
by dafassi
JimStar wrote:OK, so I make it 100/200?..
+1
