Page 29 of 31
Re: OctaneRender for Rhino 3.00 [TEST]
Posted: Tue May 24, 2016 7:02 am
by face_off
I have refreshed the installer at the top of this thread with:
3.0.20.65
- Compiled with Octane 3.00 (3.0.20)
- Fixed issue where the Reflections shadow pass was not working
- If you have ticked "Use offline licensing on this computer" when authenticating the plugin, you can now click the Deactive button on the OctaneLive tab to de-activate the plugin license
Posted: Tue May 24, 2016 10:30 am
by Refracty
Hi Paul,
I experience full Rhino crashes when the plugin is not loaded (un-ticked in the plugin options).
System: official V3 build with new Rhino V3 plugin release, latest Nvidia Driver and Quadro K6000 win 64 bit
Posted: Tue May 24, 2016 11:14 am
by face_off
If the plugin is not loaded, then it would not be the plugin causing the crash. Do you have a crash report on your desktop?
Posted: Tue May 24, 2016 12:16 pm
by Refracty
This happened at a client machine. I can not say if I can access and send a crash report at the moment.
Posted: Tue May 24, 2016 9:32 pm
by face_off
If Rhino is crashing when the plugin is NOT loaded...then it doesn't seem Octane related. I would need to see the crash report to give any more details.
Re: OctaneRender for Rhino 3.01 [TEST]
Posted: Wed Jun 08, 2016 7:15 am
by face_off
I have updated the installer at the top of this thread with:
3.0.22.66 (8-Jun-2016)
- Compiled with Octane 3.01 (3.0.22)
- EXPERIMENTAL: Added the ability to convert an Octane Material to a NodeGraph type, which can be edited in the Octane node graph window. See https://youtu.be/Yd7jkAnRZpg for details.
- Fixed issue causing the FOV to be calculated incorrrectly when Safe Frame was enabled in Rhino
- "Int" nodes can no longer be converted to "Int Resolution" nodes
- Fixed some issues related to converting of the old resolution node to the new film settings resolution node
- Added new authentication settings window which can be used to activate, and de-activate the plugin
- You can now disconnect the Medium from the Environment Medium pin
Posted: Wed Jun 08, 2016 8:27 am
by prehabitat
face_off wrote:- EXPERIMENTAL: Added the ability to convert an Octane Material to a NodeGraph type, which can be edited in the Octane node graph window. See https://youtu.be/Yd7jkAnRZpg for details.
Woah, this is cool! time to upgrade!
Posted: Wed Jun 08, 2016 8:31 am
by Refracty
Paul, you are the best.
Posted: Wed Jun 08, 2016 1:25 pm
by v-cube
Refracty wrote:Paul, you are the best.
indeed!
Posted: Thu Jun 09, 2016 1:15 am
by franchais
Thx Paul, Node graph is great!
