Page 27 of 31
Re: OctaneRender for Rhino 3.0.6 [TEST]
Posted: Fri Apr 15, 2016 2:29 am
by neiwei845458454
face_off wrote:when I update to the octanerender for rhino v2.24 to v3.x released, how much should I pay for this? or I only need pay for v3.x stand-alone released and I dont pay for plugins of rhino.
How about this?
I don't know Alxen. I'm sure Otoy will make an announcement regarding this shortly.
OK,Thank you.
Could OctaneRender may support the highest memory in the Multiple graphics cards? Now It supports the smallest graphic memory in the Multiple graphics cards.
Posted: Fri Apr 15, 2016 6:57 am
by face_off
My guess is that this would not be possible, however you would me to put this question to the Otoy team in the Octane Standalone thread to find out for sure.
Posted: Fri Apr 15, 2016 8:49 am
by neiwei845458454
face_off wrote:Could OctaneRender may support the highest memory in the Multiple graphics cards? Now It supports the smallest graphic memory in the Multiple graphics cards.
OK,Thank you.
Posted: Mon Apr 18, 2016 12:05 pm
by face_off
OK,Thank you.
Sorry for my typo - that should have read "My guess is that this would not be possible, however you would NEED to put this question to the Otoy team in the Octane Standalone thread to find out for sure."
Posted: Tue Apr 19, 2016 4:19 am
by face_off
I have refreshed the installer at the top of this thread with:
3.0.6.63
- Fixed error when the Hide and the Scale/Rot From Block Instance checkboxes are not being saved for proxy objects
- Changed OctaneChangePinValue command so the pin to be changed can be embedded in another pin, using the ':' separator. For example "OctaneChangePinValue camera:aperture 5", or "OctaneChangePinValue environment:texture:gamma 1", or "OctaneChangePinValue camera:fstop 3". See
https://docs.otoy.com/Rhino/?page_id=711 for details.
- Added OctaneAutoAssignBakingGroups command which will assign a different baking group to every geometry item in the scene which has Live Update enabled. See
- Fixed bug where unticking Live Update would disable live updating of all geometry items
Posted: Tue Apr 19, 2016 7:13 am
by neiwei845458454
face_off wrote:I have refreshed the installer at the top of this thread with:
3.0.6.63
Hi Paul,
Thank you for your help. I see the OctaneChangePinValue command was improved. Thanks,I love this. And does this OctaneChangePinValue command suppper to OctaneRender for Rhino 2.24.2.56? I need to use this version.
I found one problem. Can you make a slider button for the hdri texture environment rotation by the Z-axis rotation angle? Just like a quickly tool likes Scale Textures slider button.
- slider.png (9.48 KiB) Viewed 4852 times
Does it possible?
Best Regards,
alxen
Posted: Tue Apr 19, 2016 9:38 am
by face_off
Done - pls see the STABLE release thread.
You can already do this by opening the Environment->Texture->Projection->Sphere Transformation node and moving the Y Rotation slider.
Posted: Tue Apr 19, 2016 2:04 pm
by neiwei845458454
face_off wrote:And does this OctaneChangePinValue command suppper to OctaneRender for Rhino 2.24.2.56? I need to use this version.
OK, Thank you.
Hi Paul,
I also need the OctaneScript command to support for this, like this:
I need to set it every time. I hope one script command for solve this.
Thanks for your help.
Alxen
Posted: Wed Apr 20, 2016 12:05 am
by face_off
Ah yes, sorry, I will put that in the next release.
Posted: Wed Apr 20, 2016 2:34 am
by neiwei845458454
face_off wrote:I also need the OctaneScript command to support for this, like this:
Very Good! Thank you Paul.
