Page 27 of 54
Re: Beta 2.2 RC1: SoftImage XSI plugin testing thread
Posted: Sat Jun 12, 2010 4:06 am
by face
El Burritoh wrote:I'm running Softimage 2011 64-bit with Octane beta 2.2....just bought that yesterday as a matter of fact. Awesome tool!
The xsi addon installs just fine of course, but when I point it to the Octane exe, it fails and tells me to use Octane 2.2. I've double-checked, and yes, I am running Octane 2.2. So I'm not sure how to proceed.
When you haved downloaded this one http://www.refractivesoftware.com/forum ... =24&t=1803 it should be work...
face
Posted: Sat Jun 12, 2010 5:55 am
by El Burritoh
Yep, that's the one alright. I grabbed the Windows 7 64-bit version of the 2.2 beta, and the plugins from that same page... No luck.
Posted: Sat Jun 12, 2010 9:54 am
by face
Try to change the octane_64.dll with the one from the zip in the folder:
C:\Users\xxx\Autodesk\Softimage_2011\Addons\Octane_Exporter\Application\Plugins
before you start Softimage.
octane_x64.zip
(82.37 KiB) Downloaded 287 times
Then start Softimage, run the addon under File->Export->Octane_exporter
Choose the Octane Execute under the Project Configuration, open the script editor and tell me, what you see.
You should see "' INFO : buff: x" where x is any value, tell me that value.
face
Posted: Sat Jun 12, 2010 11:10 am
by face
Have found a issue with the "Skip Rendered Frames" option.
For rigid bodys, it doesn´t work correct while the calculation of the simulation is ever a little bit different so that the frames doesn´t match.
For that you should freeze the animation.
For Pointclouds, you should use the write to chache function, when the addon is out ;)
I found that, while Octane like to crash when i render a animation. About 3-5 times in 100 frames.
Maybe i can catch the freezes from Octane, kill the process and send the same data again to Octane, so that you can render a animation in one time, without to render skipped frames while Octane crashed.
face
Posted: Sat Jun 12, 2010 11:31 am
by radiance
face wrote:Have found a issue with the "Skip Rendered Frames" option.
face
it would be handy if we can figure out why it crashes,
can describe in detail what happens ?
Radiance
Posted: Sat Jun 12, 2010 11:57 am
by face
face
Radiance
First try:
Frame 58 visual c++ runtime error but Octane closed so fast that i can´t see anything.
Frame 62 crash.
I have opened the report metadata.
Maybe i start octane again before another session is not closed.
While i see two times the octane.exe
Will try to insert a delay...
face
<?xml version="1.0" encoding="UTF-16"?>
<WERReportMetadata>
    <OSVersionInformation>
		<WindowsNTVersion>6.1</WindowsNTVersion>
		<Build>7600 </Build>
		<Product>(0x1): Windows 7 Ultimate</Product>
		<Edition>Ultimate</Edition>
		<BuildString>7600.16539.amd64fre.win7_gdr.100226-1909</BuildString>
		<Revision>1</Revision>
		<Flavor>Multiprocessor Free</Flavor>
		<Architecture>X64</Architecture>
		<LCID>1031</LCID>
	</OSVersionInformation>
	<ParentProcessInformation>
		<ParentProcessId>4760</ParentProcessId>
		<ParentProcessPath>G:\softimage\Softimage_2011_64\Application\bin\XSI.exe</ParentProcessPath>
		<ParentProcessCmdLine>"G:\softimage\Softimage_2011_64\Application\bin\XSI.exe"  </ParentProcessCmdLine>
	</ParentProcessInformation>
	<ProblemSignatures>
		<EventType>APPCRASH</EventType>
		<Parameter0>octane.exe</Parameter0>
		<Parameter1>0.0.0.0</Parameter1>
		<Parameter2>4bfd69b2</Parameter2>
		<Parameter3>octane.exe</Parameter3>
		<Parameter4>0.0.0.0</Parameter4>
		<Parameter5>4bfd69b2</Parameter5>
		<Parameter6>c0000005</Parameter6>
		<Parameter7>00000000001fbe8a</Parameter7>
	</ProblemSignatures>
	<DynamicSignatures>
		<Parameter1>6.1.7600.2.0.0.256.1</Parameter1>
		<Parameter2>1031</Parameter2>
		<Parameter22>e97e</Parameter22>
		<Parameter23>e97e1abcd939503a507d25693ab54034</Parameter23>
		<Parameter24>f70d</Parameter24>
		<Parameter25>f70da7d5357670643ec4ed1a63fff6d9</Parameter25>
	</DynamicSignatures>
	<SystemInformation>
		<MID>1F1C06D1-E49C-4D9B-8605-6F7D4F6C079E</MID>
		<SystemManufacturer>Gigabyte Technology Co., Ltd.</SystemManufacturer>
		<SystemProductName>EP45-DS3P</SystemProductName>
		<BIOSVersion>F9c</BIOSVersion>
	</SystemInformation>
</WERReportMetadata>
Posted: Sat Jun 12, 2010 12:03 pm
by radiance
It's possible for octane to crash on startup if another instance is still running, and has a decent block of GPU memory used.
maybe this is the issue ?
Radiance
Posted: Sat Jun 12, 2010 12:06 pm
by face
radiance wrote:It's possible for octane to crash on startup if another instance is still running, and has a decent block of GPU memory used.
Radiance
Maybe, i will try to add a delay for 1000ms so that Octane can shut down.
face
Posted: Sat Jun 12, 2010 12:24 pm
by face
Now it works...
face
Posted: Sat Jun 12, 2010 12:36 pm
by radiance
I think it might be good if you do a check of some sorts to make sure octane has quit.
Radiance
