Page 22 of 26
Re: Beta 2.2 RC1: 3Ds Max plugin testing thread
Posted: Wed Jun 16, 2010 10:41 am
by kilaD
So the change has to be made in the way Octane handles the "edit" command? yes I have tried the single slash on every instance it looks it behaves the same
Now the "Octane freeze through the script when material nodes are connected", I am suspecting is also some sort of bug on Octane's side, what do you think? (EDIT: again, I have tried manually typing the same command and it's still a freeze)
thanks man, without your feedback I think I would've gone mad!
Hehe
About the "Octane freeze through the script when material nodes are connected", i haven't tried this yet, will check it out now.
btw, to check the string sent to octane:
- Copy the stringstream from the max listener i.e: ""N:\OCTANE\OctaneRender_COM_1022_beta22_RC3_win_x64\octane.exe" -e -n X:\GFX\Project\boxes\\test2.ocs -m test2.obj................"
- Then set the variable str="\"N:\OCTANE\OctaneRender_COM_1022_beta22_RC3_win_x64\octane.exe\" -e -n X:\GFX\Project\boxes\\test2.ocs -m test2.obj................"
(remember to put a \ before each quote around the path to octane)
- Then evaluate: HiddenDOSCommand (str as string) donotwait:true
Posted: Wed Jun 16, 2010 10:43 am
by kilaD
New threads for each version of the script:
Max 2010+:
http://www.refractivesoftware.com/forum ... =27&t=2359
Max 2008-2009:
http://www.refractivesoftware.com/forum ... =27&t=2360
Please use these for further questions etc...
k
Posted: Wed Jun 16, 2010 4:22 pm
by tomacmuni
Can I see a video capture of the animation export which uses deforming animation and textures?
I watched the video at the thread start, but it is video with camera animation only actually.
I have tried many variations and fiddling around to try and get it to work, and no joy.
I doubt it's a vista problem (except maybe the assertion crash, but that seems to not happen now ... so much).
I'm just not getting the texture working when I export animation from 3dsmax with the .ocs previously saved.
I want to see it, so I can check if I am doing it ok (I think I am, but hey).
Posted: Wed Jun 16, 2010 6:22 pm
by kilaD
tomacmuni wrote:Can I see a video capture of the animation export which uses deforming animation and textures?
http://www.refractivesoftware.com/forum ... 920#p22920
Posted: Thu Jun 17, 2010 7:56 am
by Florinmocanu
I have one question KilaD. Why do the OBJ export setting for scale is pre-defined at 0.025?. I model everything in centimeters, real scale. So when i export the scale is so low that even a value of 1 for aperture is almost total blur. I have hard time having a good focal depth.
Why is the scale preset at that value? It doesn't make sense to export at scale 0.025 when the best way would be to export at scale 1 and inform people they have to model things in scale.
Posted: Thu Jun 17, 2010 8:33 am
by kilaD
Florinmocanu wrote:I have one question KilaD. Why do the OBJ export setting for scale is pre-defined at 0.025?. I model everything in centimeters, real scale. So when i export the scale is so low that even a value of 1 for aperture is almost total blur. I have hard time having a good focal depth.
Please use the new threads for further questions.
It is not preset on that value, it depends on what your system scale is. Try changing your system scale to meters and see what happens.
Posted: Thu Jun 17, 2010 8:49 am
by Florinmocanu
my display unit scale is in metric system, meters. But, the system unit setup has to match it right? Because system unit is still left in inches.
Posted: Thu Jun 17, 2010 9:06 am
by kilaD
That's why it's 0.025. Set it to meters, and it will be set to 1 in the objexp.
But anyway this is done automatically so octane gets the geometry in meters
Posted: Thu Jun 17, 2010 9:44 am
by Florinmocanu
i see. Thanks for the info. You should put this piece of info in the main download thread, so that any new-comer can read what settings he should use with max.
Posted: Thu Jun 17, 2010 11:45 am
by kilaD
Florinmocanu wrote:i see. Thanks for the info. You should put this piece of info in the main download thread, so that any new-comer can read what settings he should use with max.
He can use whatever, that's the point! It's all automatico fantastico!
