Page 22 of 54
Re: Beta 2.2 RC1: SoftImage XSI plugin testing thread
Posted: Wed Jun 02, 2010 10:43 pm
by face
Amplitude wrote:hey guys,
the problem I'm having now is that the model is too smooth... really need these user normals :mrgreen: to be able to set different smoothing angles per object.
With the update ;)
face
Posted: Wed Jun 02, 2010 10:53 pm
by face
///// NEW UPDATE /////
You can download and read changes from the second post here.
face
Posted: Thu Jun 03, 2010 12:58 am
by mlody47
thank You ill check it :)
can I have a little request?? How hard would be to implement something like like "skip rendered frames", so if Im not watching and something crashed. I can just hit render with no worries.
It s a "lifsaver" :)
Posted: Thu Jun 03, 2010 1:34 am
by cgndev
Face! Thanks for your updated exporter.
But, i can't export with textures. :cry:
Are you still developing?
Posted: Thu Jun 03, 2010 5:43 am
by face
mlody47 wrote:thank You ill check it :)
I will show ;)
face
Posted: Thu Jun 03, 2010 5:48 am
by face
cgndev wrote:Face! Thanks for your updated exporter.
When you want to export textures on a existing Octane project, you must check the option "Overwrite Existing Project".
Octane use the materials on the saved project. But you lost then all your settings that you have make in Octane.
face
Posted: Thu Jun 03, 2010 7:59 am
by face
Skip rendered frames in work ;)
Will bake it in the next update...
face
Posted: Thu Jun 03, 2010 8:37 am
by Amplitude
great update face :!:
>image moved to WIP gallery
Posted: Thu Jun 03, 2010 1:56 pm
by SonarPhoton
Hi
First thanks for your hard work!
I stumbled over a little problem, when a texture is in a folder or path with a folder with a name containing a space between the letters it doesn't open in octane. Looks right in the mtl file, so this might be a bug on octanes side.
Example:
C:\foto\img.jpg works
C:\fo to\img.jpg don't
My problem is i have the whole main texture library under a folder with space in the name, so if it is possible to fix this somehow i would appreciate that:-)
Posted: Thu Jun 03, 2010 2:53 pm
by cgndev
SonarPhoton wrote:Hi
Example:
Yes! You are right!
I too can't exporter textures with a containing a space.
