Page 3 of 3
Re: Octane 2026.1 for Cinema4D - v1.8.1
Posted: Thu Dec 11, 2025 4:22 pm
by astrofalcon
Getting a fair amount of crashing with this build and C4D 2026.1. Tricky for me to pinpoint. In one scene I had some bad geometry that I removed and that seemed to fix it, in another scene though I'm getting a few crashes while rendering in the picture viewer.
Please let me know how I can better help squash these bugs!
Posted: Fri Dec 12, 2025 1:04 pm
by ChrisHekman
astrofalcon wrote: Thu Dec 11, 2025 4:22 pm Getting a fair amount of crashing with this build and C4D 2026.1. Tricky for me to pinpoint. In one scene I had some bad geometry that I removed and that seemed to fix it, in another scene though I'm getting a few crashes while rendering in the picture viewer.
Can you share a crash scene with us? If its big you can just delete everything that doesnt crash
Posted: Fri Dec 12, 2025 4:10 pm
by POPX
Hello, I’m having a small issue after reopening my scene that was created with a 2025 version. I’m experiencing slowdowns and occasional crashes. The log shows several errors, and I would like to know how to fix or rebuild the materials that are causing the problem.
Here is a copy of the log:
Started logging on 12.12.25 16:51:39
OctaneRender Studio+ 2026.1 (15000009)
initOCIOconfig cfgFile: OCIO_ENV:
disableAllDevices
VRAM used/free/max:0Kb/31.842Gb/31.842Gb Out-of-core used:0Kb RAM used:24.756Gb total:127.897Gb OpenGL free/total:0/0
Export materials time= 140289.321 ms
Collect objects time= 54.674 ms
Mesh creation time = 9015.656 ms.
Tried to access pin via an invalid ID P_TRACE_SETS (2637)
Tried to access null node pin
Can't write string to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFC73CB1DD0)
Tried to access pin via an invalid ID P_SHADOWS_EXCLUDE (2721)
Tried to access pin via an invalid ID P_SHADOWS_REINCLUDE (2722)
Api update time: 9.242 ms.
VRAM used/free/max:15.746Gb/12.782Gb/31.842Gb Out-of-core used:0Kb RAM used:65.617Gb total:127.897Gb OpenGL free/total:0/0
could not pick, because the geometry has changed and rendering is paused
Posted: Mon Dec 15, 2025 11:33 am
by POPX
I noticed an issue with my older scenes, especially at the final render stage. When I kept my presets with MID or Z passes enabled, the render would crash. Since then, I’ve only been getting errors and crashes in the Live Viewer, but with a bit of patience, I’m managing to keep going on this project.
Posted: Mon Dec 15, 2025 3:56 pm
by astrofalcon
ChrisHekman wrote: Fri Dec 12, 2025 1:04 pm
Indeed! I'll try and narrow it down within a simple C4D scene and send it over!
