Page 3 of 18
Re: Cinema4D version 2021.1.6 (Latest stable) 24.08.2022
Posted: Sun Aug 28, 2022 9:02 pm
by Kalua
Hi, Aoktar
I think I found a bug.
I created a scene with 2021.1.5. Now I am copying some geometry with shaders and pasting it on a new file using 2021.1.6 - not sure if this is the cause of the bug.
When I paste the content o the new scene, the geometry and shaders come in, but I can't find the shaders on the Material Manager. The other way around it works fine. I am on R21.207
Is there something I am missing? Never seen this happen before.
Posted: Sun Aug 28, 2022 10:52 pm
by aoktar
Kalua wrote:Hi, Aoktar
Why do you call everything as a bug? I didn't make any change to cause this, even I don't know how I can do this if I'd like to do! Have you checked what you do?
Posted: Sun Aug 28, 2022 11:09 pm
by SSmolak
There is no issues with copy-paste object from different scene with materials. Materials are copied too. You should check that maybe you have them in different layer...
Posted: Mon Aug 29, 2022 12:18 am
by Kalua
Well my mistake then. Seemed like a bug to me. I must have done something wrong.
I will check what is going on with these files. There are no layers.
Thanks for everything.
Regards,
PS.: Found the problem: The "Q Material Filter" plugin was filtering some materials on Material Manager... and was weird because I checked and it and it wasn't active. After toggling its settings it fixed the view. So sorry for reporting this here.
Re: Cinema4D version 2021.1.6-(R2) (Latest stable) 31.08.2022
Posted: Wed Aug 31, 2022 4:52 pm
by Kalua
2021.1.6-(R2) working great here!
Thanks , Aoktar!
Posted: Thu Sep 01, 2022 12:16 am
by aoktar
Kalua wrote:2021.1.6-(R2) working great here!
Thanks , Aoktar!
Enjoy it! Thanks for feedback!
Posted: Sun Sep 04, 2022 12:26 pm
by miohn
This is strange!
After installing 2021.1.6-(R2) whatever project I load all my textures got changed.
F.e. a wood texture has in all image-texture-slots (Albedo, Spec, Normal etc.) suddenly a total different
image (a normal-map from a different plastic material) loaded.
Even the texture in my HDRI Env has this material loaded.
Any idear???
thanks Mike
Posted: Sun Sep 04, 2022 9:18 pm
by aoktar
miohn wrote:This is strange!
Any idear???
thanks Mike
Can you provide some example scene?
Posted: Mon Sep 05, 2022 8:53 am
by miohn
Hi Ahmet,
went back to R1 yesterday and today installed R2 again.
Same like yesterday. All materials changed the texture.
Please see screen for example.
All the ca. 50 materials in this scene now got this tree-texture applied even
material preview still showing the correct texture.
And this texture-change happens to all my other jobs/projects but with
another texturemap applied to all materials.
Again wneed to go back to R1
regards
Mike
Posted: Mon Sep 05, 2022 12:18 pm
by aoktar
miohn wrote:Hi Ahmet,
regards
Mike
I need the your project to say something. Can you share it with textures?
