Page 3 of 3
Re: Ripple Effect with Octane
Posted: Tue Dec 29, 2020 4:16 am
by lanklaf
pinarer wrote:@lanklaf it worked!! thank you!! :)
You are welcome :) ,by the way, adjust the spline offset or add and change a time field so that ripples only appear when a raindrop hits the surface.
You can also increase the ripple area somewhere in the displacement settings.
Good luck with your project!
Posted: Tue Dec 29, 2020 7:54 am
by pinarer
@lanklaf, there is spline offset and inner offsets, i played around with tthose but it didint change anything with timing, am I looking at the wrong spot?
Posted: Tue Dec 29, 2020 12:07 pm
by lanklaf
pinarer wrote:@lanklaf, there is spline offset and inner offsets, i played around with tthose but it didint change anything with timing, am I looking at the wrong spot?
I found an easier way, just place your sphere in a null object that has Y = 0,
then adjust the Y of the sphere until ripples only appear when sphere touches the surface:
Basically you just moving the center of the particle:
Posted: Tue Dec 29, 2020 5:05 pm
by pinarer
@lanklaf, yes! that worked, wow, it wouldn't cross my mind to solve that way, thanks!! again for all the help! learned alot!
Posted: Tue Dec 29, 2020 5:10 pm
by lanklaf
pinarer wrote:@lanklaf, yes! that worked, wow, it wouldn't cross my mind to solve that way, thanks!! again for all the help! learned alot!
You are welcome :) ;)
Posted: Tue Dec 29, 2020 7:12 pm
by pinarer
@lanklaf, not sure if you check your DM on here, but just sent one, just to let you know :)
