Page 3 of 3
Re: Fatal error: Segmentation fault
Posted: Wed Dec 11, 2019 5:42 pm
by juanjgon
pm sent
Posted: Wed Dec 11, 2019 6:26 pm
by juanto_92
Thaanks!!
Posted: Tue Dec 17, 2019 2:31 pm
by motionskill
I found that I have the same issue on scenes with many elements like Fur, Hair and when I hit "Update" in IPR. Reload button is working fine
Posted: Tue Dec 17, 2019 2:56 pm
by juanjgon
motionskill wrote:I found that I have the same issue on scenes with many elements like Fur, Hair and when I hit "Update" in IPR. Reload button is working fine
Hmm, I'm not sure if this is the same problem, because this crash was related directly to the reload function while rendering scenes in full scene reload mode. Can you please enable the Octane log file in the plugin options panel and attach the log that you get after one of these crashes?
Posted: Tue May 04, 2021 7:59 am
by tschwenke
Hi Juanjo,
Any chance I can get such a revised version. I'm still using 17.0.506 and 4.05.0.0 while having the same problem with a current project. A version where the "Full reload" function works would be nice :)
Posted: Tue May 04, 2021 8:16 am
by tschwenke
Or perhaps a hint what I can do to prevent the problem... Some scenes seem to work fine, others not, so there might be a simple solution by just doing something or not doing something.
Posted: Tue May 04, 2021 9:20 pm
by juanjgon
Sorry, I'm afraid that Octane 4.05 is no longer supported. If you have this problem you could try to render the scene frame by frame using a script or a renderer controller like Deadline to avoid the scene reloading crash.
Posted: Thu May 06, 2021 8:02 pm
by tschwenke
Ok, thank you though.
