Page 3 of 3
Re: Texture Transform
Posted: Wed Sep 17, 2014 12:37 pm
by aoktar
NVN wrote:sry aoktar, but the transform tool is totaly confused.
maybe it is a bug....i hope u can help me.
My texture was ok, but there are some strange errors?
no, you should be more explorer. I did a test, chk please. box mapping does streched pixel on sides
Posted: Wed Sep 17, 2014 1:13 pm
by NVN
aoktar plz look at my example.
there are red dots in the middle....But there should be nothing!!
Posted: Wed Sep 17, 2014 1:23 pm
by aoktar
this is result of your mapping on a simple cube. Check sides. It does same on your mini cubes. Sorry forgot to say, i did scaleY=0.001 on first example
Posted: Wed Sep 17, 2014 2:11 pm
by NVN
yes, i tested last night the same (scaley=0.001)
but they are visible too, not strong but visible.
Maybe flat mapping helps?
but how can i map from the top???
Posted: Wed Sep 17, 2014 2:48 pm
by aoktar
NVN wrote:yes, i tested last night the same (scaley=0.001)
assing to only top faces
Posted: Wed Sep 17, 2014 3:26 pm
by NVN
where can i found this??
edit:
u mean in C4D with polygone selektion?
Wont work, my polygons on the side, needs the same color.
Posted: Wed Sep 17, 2014 3:28 pm
by aoktar
NVN wrote:where can i found this??
i mean that assigning a material to selection of faces
Posted: Thu Sep 18, 2014 3:05 pm
by NVN
ok...but how can i get the same color on the side?
Posted: Thu Oct 23, 2014 6:30 pm
by jblessing
Maybe I missed something, but it usually works fine for me to use cubic etc. to position a texture how I want and then go 'generate uvw' on that texture tag before I load it into octane. It would be nice if it would translate it for you, but that doesn't seem to be the case.
