Page 3 of 3
Re: Rhino Plug-in 1.022r01.01
Posted: Thu Oct 14, 2010 4:07 am
by SamPage
timbarnes wrote:The file is present but empty. I deleted it to see if the plugin would create a new one, but after running OctaneOptions again, no ini file was created. I got the same script error, however.
OK, thanks. I see where I am not catching the error properly, but am still at a loss why the script is having trouble reading your cards. I will try and work up a "chatty" version of the script you can run tomorrow so you can send me the output and get a better idea of why it is failing for you.
Thanks again,
Sam
Posted: Fri Oct 15, 2010 4:24 am
by timbarnes
Sounds good. I'll look for it.
tim
Posted: Fri Oct 15, 2010 1:03 pm
by justix
Is Export with save location still in the pipeline? ;)
