Page 3 of 4
Re: Alpha Rest Room
Posted: Wed Nov 14, 2012 6:31 am
by merid888
hi enrico, maybe can you explain a little bit about work mesh light ? i mean, how use it ?
regards
Re: Alpha Rest Room
Posted: Wed Nov 14, 2012 6:22 pm
by enricocerica
Refracty wrote:great work - Did you try pmc / pt for comparsion?
No, I didn't try with PMC, I'm sure the result would be better as PMC like path better handles indirect light but it's really too slow for me in such environments.
Re: Alpha Rest Room
Posted: Wed Nov 14, 2012 6:24 pm
by enricocerica
paoloverona:Thanks, much appreciate
merid888:Well, really nothing special, if the windows are not visible I just convert the window glass in an emiter to create a fake incoming light
Re: Alpha Rest Room
Posted: Wed Nov 14, 2012 6:36 pm
by merid888
thank you enrico you are friendly, i'll try to practice this step
is different put just an octanelight or is the same thing ? just i need put the glass window into octanelight ? or i'm wrong
regards
Re: Alpha Rest Room
Posted: Wed Nov 14, 2012 6:38 pm
by enricocerica
merid888 wrote:thank you enrico you are friendly, i'll try to practice this step
regards
Yes, just convert the glass window into octanelight
Re: Alpha Rest Room
Posted: Wed Nov 14, 2012 6:44 pm
by merid888
thank you enrico
i'll do my best effort to pratice
regards
Re: Alpha Rest Room
Posted: Sat Nov 24, 2012 5:12 pm
by merid888
hi enrico, good morning from merida, i would know if you can support me, how values do you use when use the emiter light in the windows, i use power 100, efficency 0.015, samples 0.001 is correct ? or i'm wrong ?
hope you can help me
thank you
Re: Alpha Rest Room
Posted: Sat Nov 24, 2012 5:20 pm
by enricocerica
merid888 wrote:hi enrico, good morning from merida, i would know if you can support me, how values do you use when use the emiter light in the windows, i use power 100, efficency 0.015, samples 0.001 is correct ? or i'm wrong ?
thank you
Well, to be honnest I don't remember and I didn't keep the settings as I change many values in the scene from one view to another. By the I remember that I had to set a high value and probably more than 100 and also a higher efficency. The best way is to experiment to find the best settings, playing with the sliders you'll quickely see if the result is ok.
Re: Alpha Rest Room
Posted: Sat Nov 24, 2012 8:20 pm
by merid888
well, thank you for comment, maybe the time and practice more is the bets effort to do a realistic images like your
regards
Re: Alpha Rest Room
Posted: Sat Nov 24, 2012 11:08 pm
by merid888
one last question enrico, when you talk about pagination for graphic cards, what do you mean ? is an configuration ? is about operating system ? where i can read about this to do more fast my gtx470 ?
thank you
