Page 3 of 5
Re: 3ds max -> Octane export script
Posted: Tue Apr 27, 2010 10:00 pm
by justix
kilaD wrote:yes that one, i uploaded a new bugfixed version. think of it as 0.41 :)
the top one still looks 0.4 but if you have update the content I re-download that again........
Posted: Tue Apr 27, 2010 10:18 pm
by justix
nope still the same.....
Posted: Tue Apr 27, 2010 10:54 pm
by kilaD
Is there any geometry in the scene when you start it? If not it fails. I never thought it would be opened in an empty scene.
Try making a box, then start it and see if it works.
The script is not 100% foolproof yet. :)
Posted: Wed Apr 28, 2010 12:25 am
by Javadevil
kilaD wrote:javadevil: press the hammer :) doubleclick octane.exe - then export and it should work. What max version do you have?
n1k: Turbosmooth issue fixed in updated script
k
Yes thats what I tried.
I'm using 3dsmax Design 2011
Posted: Wed Apr 28, 2010 12:48 am
by kilaD
Should work, i have 2011 as well. Download the latest version (0.42) try again and let me know
Posted: Wed Apr 28, 2010 6:40 am
by justix
kilaD wrote:Should work, i have 2011 as well. Download the latest version (0.42) try again and let me know
Thanks, I think extremely useful indeed...
Now with the 0.42 it does open and extract without error BUT when octane open I have this:
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: Settings\m\My
Tried 2 different scene, converted to scanline and camera is not a Vray (in my case that I have several Vray scene already made)
and also made a new scene from scratch with a simple plane and a teapot to test...no joy
Posted: Wed Apr 28, 2010 11:31 am
by kilaD
Go to your octane root, check the oct.bat which the script generated(rightclick and edit).
Paste the content here and I`ll check it.
edit:
it looks like a path on your drive, settings/m/My...
if so, it`s probably the space in "My documents" which breaks the code.
Anyone have a clue how to fix this? How do you write paths with spaces (i.e My Documents) in DOS?
"My_Documents" or "My~doc" ?
Posted: Wed Apr 28, 2010 12:23 pm
by justix
kilaD wrote:Go to your octane root, check the oct.bat which the script generated(rightclick and edit).
edit:
as soon as I'm home I'll check out and post...thanks!
Posted: Wed Apr 28, 2010 12:38 pm
by [gk]
edit:
Find my DOS bat and check it, will sove this problem.
Posted: Wed Apr 28, 2010 12:40 pm
by [gk]
@echo off
for %%f in (*.obj) do (
start "" /wait "C:\Program Files\Refractive Software\Octane Render 1.02 x64\octane.exe" -e -m %1 -r c:\test\%%f -s 400 -o c:\test\test_%%~nf.png c:\test\master.ocs
pause
