Page 17 of 19
				Re: Version 2.21.1
				Posted: Fri Mar 20, 2015 5:39 am
				by Oleg
				aoktar wrote:Try to explode faces to groups
Sorry, can't understand — how to do that?
				Re: Version 2.21.1
				Posted: Fri Mar 20, 2015 12:44 pm
				by shawnfrueh
				Hey Aoktar,
I had a problem yesterday while rendering out an animation where the Render layer mask would freeze halfway though the samples. It wasn't consistent as to which frame would lock up. Have you have any issues with this?
Secondly, is the network rendering not working in 2.21.1? I keep getting invalid version even though everything is set to the 2.21.0 standalone.
				Re: Version 2.21.1
				Posted: Fri Mar 20, 2015 12:49 pm
				by aoktar
				shawnfrueh wrote:Hey Aoktar,
-yes, it's a bug on sdk. We are still waiting fixed sdk for this renderpass problem.
-Your versions should be same, 2.21.1 is not equal to 2.21.0
				Re: Version 2.21.1
				Posted: Fri Mar 20, 2015 2:09 pm
				by shawnfrueh
				Ahh! I completely missed the 2.21.1 Standalone, everything is working now. I'm really liking this latest version!
				Re: Version 2.21.1
				Posted: Fri Mar 20, 2015 3:38 pm
				by momade
				Oleg wrote:aoktar wrote:Try to explode faces to groups
or you try the c4d native sub-frame-motion blur..
if you try so you can reduce the spp per frame drastically, because c4d will render up to 49frames per frame.
br.
mo
				Re: Version 2.21.1
				Posted: Fri Mar 20, 2015 8:47 pm
				by caffe3
While waiting for the SDK to be updated, you could try increasing the Kernel max samples. My renders were constantly freezing in picture viewer when I tried setting the Kernel samples really low.
				Re: Version 2.21.1
				Posted: Sat Mar 21, 2015 4:07 am
				by shawnfrueh
				The samples were at 256 (the masks) can't go much lower. I actual upped them to 512 while the beauty was at 1600 but I found a solution using team-viewer which makes absolutely no sense but running the computer through that solved all of the crashing. Its been going for over 5 hours now with no crashes. close team-viewer and its back to getting stuck every 10-20 minutes.
				Re: Version 2.21.1
				Posted: Sat Mar 21, 2015 8:16 am
				by nbeyond
				Since i installed the 2.21.1 version i´ve always get this errror massage at start! (3 times in a row)
Standalone version is 2.17!
I also tryed to reinstall both the standalon incl. the plugin but it doesn´t changed a thing!
Also if i try in cinema 4D to open the live material libary from octan it crahses.... =/
Why is in my downloadsection the cinema plugin just max. 2.16?!
				Re: Version 2.21.1
				Posted: Sat Mar 21, 2015 10:46 am
				by caffe3
				nbeyond wrote:Since i installed the 2.21.1 version i´ve always get this errror massage at start! (3 times in a row)
Read here:
http://render.otoy.com/forum/viewtopic.php?f=87&t=45194
1. On encountering DLL errors at startup, be sure to delete the other .cdl64 files (R14, 15 etc.) in the plugin folder.
nbeyond wrote:Why is in my downloadsection the cinema plugin just max. 2.16?!
It's 2.16 in download section because that's the last stable version. They don't list the new one cause it's not ready for production (development build). Lots of glitches and stuff going wrong because they added new features. If you're going to try the latest version, you need to download the plugin AND standalone 2.21:
C4D Plugin Windows
http://render.otoy.com/customerdownload ... .1-win.zip
C4D Plugin Mac OS X
http://render.otoy.com/customerdownload ... Macosx.zip
Standalone Windows
http://render.otoy.com/rcdownloads/Octa ... _win64.exe
http://render.otoy.com/rcdownloads/Octa ... _win64.zip
Standalone Mac OS X
http://render.otoy.com/rcdownloads/Octa ... _macos.dmg
				Re: Version 2.21.1
				Posted: Sat Mar 21, 2015 3:40 pm
				by nbeyond
				THX for the help!
But the problem with crashing as soon as i open the LiveDB still remains... =/   (i use now standalone 2.21.1 and plug 2.21.1)
greez
armin
