Page 15 of 18
Re: Version 4.0-RC7-R4 (Latest release candidate) 10.11.2018
Posted: Thu Nov 15, 2018 12:03 pm
by aoktar
stefano-dear wrote:
How big your texture preview size? Try to use default size and please share your scene with me if possible
I have checked all the materials and only one material was set with 2048x2048 texture preview size. I will send you the scene by PM.
Stefano[/quote]
Your scene needs some optimizations. First I don't see any problems like repeatedly producing the previews. They're done once time. Using a lot render instances are stressing the viewport and causing lags on opengl previews. Also, another problem is HDR environment is slowing down your render. Also very dense foliage with scatter object that is slowing down the render also. Alternatively, you can completely disable "opengl previews".
Posted: Thu Nov 15, 2018 12:23 pm
by stefano-dear
aoktar wrote:Also, another problem is HDR environment is slowing down your render
Why? Octane daylight could be faster?
aoktar wrote:Alternatively, you can completely disable "opengl previews".
ok!
thanks for you support!
Best Regards
Stefano
Posted: Thu Nov 15, 2018 12:30 pm
by aoktar
stefano-dear wrote:aoktar wrote:Also, another problem is HDR environment is slowing down your render
Who knows!
Btw try this option on slow scenes. Ok I'm going back to work for finishing the next build.
Posted: Thu Nov 15, 2018 12:41 pm
by stefano-dear
aoktar wrote:Ok I'm going back to work for finishing the next build.
Yeah!
Thank you!!
Posted: Thu Nov 15, 2018 11:45 pm
by rclassenphoto
if i run this plugin in Cinema 4D R19.068 BRoadcast it works but if i close Cinema 4d it freeze and i dont can close Cinema 4d. Is there any Reason for this problem? Thanks
Posted: Fri Nov 16, 2018 12:14 am
by aoktar
rclassenphoto wrote:if i run this plugin in Cinema 4D R19.068 BRoadcast it works but if i close Cinema 4d it freeze and i dont can close Cinema 4d. Is there any Reason for this problem? Thanks
Please try without any other plugins to see what happens.
Posted: Fri Nov 16, 2018 1:47 am
by rclassenphoto
ah okay... i have fix the problem, i delete a pluigin that was buggy. Thanks.....
But now i become the problem on my slave pc with network render
"detected that slave is hanging after initialization - > stopping slave
Any idea? thx
Posted: Fri Nov 16, 2018 11:06 am
by rclassenphoto
If i render only in the Picture Viewer the network render dont work it comes the message "detected that slave is hanging after initialization - > stopping slave " and it stops. If i render with the "Render Queue" it works Perfect. No errors or Problems.
Posted: Fri Nov 16, 2018 11:48 am
by rclassenphoto
And i dont know if it is a bug but if i render out the image normal with Max- Samples: 8000 the colors are great. If i render the out the denoiset version with the beauty pass and Max- Samples: 800... i have a lot loss of colors. The sharpness and noise reduction is very very good but the colors looking flat.
Posted: Fri Nov 16, 2018 11:58 am
by aoktar
rclassenphoto wrote:And i dont know if it is a bug but if i render out the image normal with Max- Samples: 8000 the colors are great. If i render the out the denoiset version with the beauty pass and Max- Samples: 800... i have a lot loss of colors. The sharpness and noise reduction is very very good but the colors looking flat.
It's used a lot! Have you checked "tonemap type" in render passes section?
