Page 15 of 30
Re: Non-offical Blender 2.56 plugin
Posted: Sun Jan 23, 2011 2:06 pm
by r4ytrace
thanks for this - going to check it out now :)
Posted: Sun Jan 23, 2011 2:25 pm
by SamCameron
Works like a charm, now the script is PERFECT, thanks for the work Yoyoz.
Posted: Sun Jan 23, 2011 4:17 pm
by r4ytrace
worked pretty great for me too :)
had to manually remove about 4 fireflies but they were easy to fix
Posted: Sun Jan 23, 2011 6:10 pm
by SamCameron
I found a bug, when you're setting up a material, once you click in Glossy , you cannot set anymore the material as Diffuse, the color wheel is OK for glossy and specular, but not for diffuse.
Posted: Sun Jan 23, 2011 6:39 pm
by yoyoz
This is a side effect of forcing intensity to 1. Just put back specular color to full 0,0,0 and the material with switch diffuse.
Posted: Sun Jan 23, 2011 8:44 pm
by steveps3
I knew that option was a bad idea.
Posted: Sun Jan 23, 2011 10:43 pm
by SamCameron
If you don't like it, don't use it, to be honest I think must be a workflow to still having this option without interfering the material set up.
Posted: Mon Jan 24, 2011 4:13 am
by vinz
Thanks for your nice work :)
Posted: Mon Jan 24, 2011 4:04 pm
by franbec
Many Thanks for the work yoyoz ,Testing it ,works great for me with the latest nightly builds.
Posted: Mon Jan 24, 2011 4:47 pm
by yoyoz
Thanks guys, I'm happy you like it!
Be prepared for an update tonight, the following will be fixed with 0.84:
- text not exported
- meta objects materials not exported
and anything I can find in the meantime...
This seems due to name changes in 2.56 API, but I can't tell from which build/version.
