Page 13 of 13
Re: Cinema4D version 2022.1-XB3-(R4) (Experimental) 23.09.22
Posted: Sun Oct 16, 2022 9:49 pm
by karl
azumbrunnen wrote:Quick question on ACES: when I turn it on, it's one check box and everything looks great. Awesome. Does that mean I no longer need to download OCIA configs etc, I just go to settings and turn on ACES tonemapping?
Yes, that's correct, if you were only using the ACES OCIO config for the sRGB output, then you don't need OCIO for that anymore.
azumbrunnen wrote:One problem I have here is that the rendering gets a lot of white pixels and I can't use a custom Octane Environment (visible environment) as soon as I turn on ACES. Any tip here?
The white pixels issue was fixed in Octane core 2022.1 XB4, so that should go away when a version of the plugin based on XB4 is released. I'm not sure about the environment issue, but that may be caused by the same problem, so please retest at that point.
Posted: Mon Oct 17, 2022 1:21 am
by SSmolak
It was caused by dark clipping areas. Increasing camera exposure can help but the best is to wait for XB4
Posted: Mon Oct 17, 2022 2:16 am
by aoktar
Posted: Thu Oct 27, 2022 9:30 pm
by michaelvelasquez
Hello,
I'm on an M1 Max MacBook Pro, Monterey 12.6. Is anyone else having issues with Open LiveDB not doing anything with this experimental version of the C4D plugin and C4D 2023.0.0? In the Octane Live Viewer I go to Materials>Open LiveDB and nothing happens. I have the Octane log open and trying to open LiveDB doesn't create any log text.
Thank you
Posted: Thu Oct 27, 2022 10:11 pm
by aoktar
michaelvelasquez wrote:Hello,
Thank you
Mac build is prime version and will not support LiveDB.
