Page 13 of 16
Re: OctaneRender for Rhino 2.25 [STABLE]
Posted: Fri Mar 04, 2016 4:00 am
by face_off
I have installed the 2.25 version in the winows10 system, finally I have closing the rhinoceros 5 (64bit), the process of computer memory was overflow, stuck unable to move.
And windows 8 64bit was also that,only windows7 works well.
Hi - can you pls only report problems in a single place - not multiple thread.
visibility bug
Posted: Mon Mar 14, 2016 11:46 am
by v-cube
Hello Paul,
I was very happy when I read that the object based visibility option was fixed, however I found out that this does only seem to work as long as the objects are not behind other transparent objects like e.g. a glass plane.
I have attached a screenshot that illustrates the problem: the red object is supposed to be invisible but becomes visible when it is obstructed by the glass.
attached please also find the scene.
https://dl.dropboxusercontent.com/u/172 ... %20bug.3dm
I hope that it is possible to fix this bug in short time, since I really need this feature right now...
best
Andreas
Posted: Mon Mar 14, 2016 12:06 pm
by v-cube
another hint, the behaviour seems to be related to the specular material, using glossy or diffuse material for the glass plane with an opacity value < 1 does not show the bug....
best
Andreas
reflection bug
Posted: Mon Mar 14, 2016 12:22 pm
by v-cube
...similar thing: although the object is not visible, it is still being reflected and casts shadows...
best
Andreas
Posted: Mon Mar 14, 2016 11:28 pm
by face_off
Hi Andreas - turning off object visibility does not remove the vertices from the scene - it just sets the opacity to 0. So try reducing the Kernel->Ray Epsilon. If that does not work, export to ORBX and post on the Octane Standalone test release thread so the Otoy devs can comment.
Posted: Tue Mar 15, 2016 10:21 am
by v-cube
face_off wrote:Hi Andreas - turning off object visibility does not remove the vertices from the scene - it just sets the opacity to 0. So try reducing the Kernel->Ray Epsilon. If that does not work, export to ORBX and post on the Octane Standalone test release thread so the Otoy devs can comment.
Hello Paul, I did a few more tests, tried out Ray epsilon and made another box with a green material on it the materials opacity was set to 0.
As I expected changing ray epsilon did nothing, also the material with the 0 opacity does not show any bugs.
I also did an orbx export and the bug also shows up in octane standalone.
I will do another test with octane 3 beta and then post in the release thread as you suggested.
best
Andreas
Posted: Wed Apr 13, 2016 4:39 pm
by v-cube
Hello Paul,
I found that the "hide" feature with proxies attached to blocks does not seem to work sometimes.
I attached a zip file with a rhino file and a orbx file to illustrate the problem.
when I check the "hide" checkbox , deselect the block and then reselect it again the check is gone.
can you repeat this ?
best
Andreas
Posted: Thu Apr 14, 2016 2:35 am
by face_off
Yes, both Hide and the Scale/Rot From Block Instance checkboxes are not being saved. This will be fixed in the next release.
Posted: Fri Apr 15, 2016 11:21 am
by v-cube
Hello Paul,
is it possible to implement the "live update" feature also for rhino blocks?
best
Andreas
Posted: Fri Apr 15, 2016 12:04 pm
by face_off
Rhino block instances always have live update ON.
