Page 13 of 13
Re: OctaneRender® for 3ds max® v1.0 RC2[Test]
Posted: Thu Nov 15, 2012 9:29 am
by suvakas
Karba wrote:
You have too long uv mapping. try to cut the road uv mapping to several parts and move to the origin.
Too long UV mapping? What does that mean?
You mean Max UV mapping is not fully supported by Octane?
I'm asking cause i've had strange UV issues with Octane too, but the same scenes work fine with scanline/mental ray.
Suv
Posted: Thu Nov 15, 2012 9:44 am
by mbetke
I was able to avoid the bug a bit if I stay under a certain amount of instances. Around 40.000-50.000 and it works. I was able to finish the project (client already asked for his renders).
Posted: Thu Nov 15, 2012 12:03 pm
by cbapog
Falloff map using in octane.
Karba, in vray i am use 2 architectural glass model whitout falloff + freshnel on (vray glass classic) and use falloff freshnel map at reflect\refract material slot + freshnel off.
classic glass
falloff glass (falloff to reflect + inverted (output) falloff to reflect instance map)
Try repeat this materials in octane (stand or integration)
classic (default vrayglass\octane specular)
pmc2000s
falloff glass (mix text (white,black,falloff mix mask) to reflect slot
pmc2000s
question: What is the parameter vray refractive in octane? to input inverted falloff map instance.
thx
Posted: Thu Nov 15, 2012 6:27 pm
by Philipp1980
Karba wrote:Plankosmos wrote:I have the following problem: I created a lamp with texture emission. It works fine when rendered alone (first picture), but if I load it into my scene, the light behaves not as supposed (second picture). Is that a known issue?
I reuploaded RC2 files 8th November. Did you download it before?
I missed that indeed!
Thx Karba, that solved the problem!
Posted: Sun Nov 18, 2012 8:04 pm
by Elvissuperstar007
Karba Look here please
http://render.otoy.com/forum/viewtopic. ... 2&start=30
Перед тем как финалку делать. совет сюда зайти
Мы нашли всетаки косяк в каустике или стекле.. не уверены. там же есть сцена
Извиняюсь за русский. просто это важно! . а тот пост никто не читает из разработчиков сейчас
Posted: Tue Nov 20, 2012 6:19 am
by truerender
Karba Look here please viewtopic.php?f=39&t=24442&start=30
Why this happening?
