Page 12 of 18
Re: Cinema4D version 2021.1.6-(R4) (Latest stable) 18.09.2022
Posted: Fri Oct 14, 2022 11:27 am
by glimpse
Posted: Fri Oct 14, 2022 2:38 pm
by blackcat321
aoktar wrote:blackcat321 wrote:2021.1.6 r4 Octane Scatter will not refresh
You're in a WIP option isn't?
yes
Posted: Fri Oct 14, 2022 3:31 pm
by aoktar
Multi posts for same issue. It's explained a lot in the topic.
viewtopic.php?f=30&t=80425&start=20
Posted: Sat Oct 15, 2022 12:31 pm
by SSmolak
Copy-Paste node removes his name :
- node copying name.jpg (13.28 KiB) Viewed 2665 times
Posted: Sun Oct 16, 2022 7:47 am
by aoktar
SSmolak wrote:Copy-Paste node removes his name :
I know it, thanks
Posted: Sun Oct 16, 2022 4:12 pm
by DiegoCP
Hi there,
The earlier issue I had seems to be fixed after reinstalling the plugin, but I'm now facing a new issue.
When dragging a material to C4D's Asset browser to create an asset, textures referenced by the shader are not being copied with the material to the Asset Browser as they used to and are keeping their absolute paths, instead of having an "assetdb:///" route like they used to. Dragging materials created in older octane versions (like 2020.2.5, if I'm not mistaken) still works, in the sense that they keep this "assetdb:///" route.
Is there a setting I'm missing?
Re: Cinema4D version 2021.1.6-(R5) (Latest stable) 17.10.2022
Posted: Mon Oct 17, 2022 2:33 am
by aoktar
New build(R5) is out, enjoy it!
Posted: Tue Oct 18, 2022 3:06 pm
by freeter_e
aoktar wrote:Kalua wrote:Hi, Aoktar
Could we have a command for "Empty TexCache"? Currently there is no way to have a buton or even to assign a shortcut to this command.
I use it to constantly to avoid instabilities and C4D freeze.
Why do you have freezes or instabilities? Contact to support please!
Hi, Aoktar
Where can I find shortcut list? I just know "d" stand for "solo"
Posted: Tue Oct 18, 2022 4:25 pm
by y81r
unfortunately I don't get an AOV custom pass rendered with EXR (Octane). I really need this!
c4d r26.107 Octane 2021.1.4 up to 2021.1.6-(R5)
Posted: Tue Oct 18, 2022 4:41 pm
by aoktar
y81r wrote:Hi,
It doesn't mean that's not working. Because it's working here, double check
