Page 12 of 34
Re: Cinema4D version 2020.1-R2 (Stable release) 29.04.2020
Posted: Mon May 04, 2020 3:18 am
by Kalua
aoktar wrote:Kalua wrote:shine71 wrote:Found it!
And it seems to work on first try...
Should I did it everytime I open a scene?
Is there a way to have it set without doing it?
Thanks a lot for your help, man!!!
I also had some issues with texture taching. I disabled texture caching to avoid from happening again - I can´t really say what are the benefits of this option.
You may prevent Octane to use this feature under the settings window.
It's not same thing we talked about it. This option is about plugin usage and keeps textures in memory during work period of a scene to load much faster for next usage. With this option Live Viewer or material previews runs much faster. No reload. My advice to keep it selected.
Other than this, "Empty texCache" command clears the Renderer's texture cache in harddrive. And it's a different story.
Thank you for the info... didn´t know they were not related... same words...
Is it different from the preference dialogue in standalone version?
Posted: Mon May 04, 2020 4:50 am
by shine71
Thanks Kalua and Ahmet!
I'm going to use that tool since guys won't fix this issue.
This will save me to use 4.05 and it's already a good thing
Please keep us posted, Ahmet!
Have a great day!
Posted: Mon May 04, 2020 8:52 am
by martinzip
Dear Ahmet
after installing the slaves on my older macs 10.12.6, the slaves stopped working with the reason that they need cuda 10 installed. In your info there is 9.1 mentioned for macosx!
Cuda 10 would ment to install 10.13.6 on the older macs? which will be a difficult task... But I think on 10.13.6 there is also only Cuda 9.1 running ... On my 10.13.6 the new version is running fine in c4d as well as a slave ...
Please check weather there is a bug in the code or I have to install high sierra to run the slaves...
Thanks for your help in advance
kind regards from sunny cologne
Martin
Posted: Mon May 04, 2020 4:25 pm
by VVG
Ahmet,
fix your online HELP.
When you try to help people and send a link by a
quick search, everyone always has a 404 error (copy/paste link dont work)
For example:
http://aoktar.com/octane/Noise1.html?search=noise
Posted: Mon May 04, 2020 9:16 pm
by thanulee
Hello, i have 2 scenes where autobump freezes the rendering when used in combination with network rendering.
C4D doesnt crash, but frame never finishes render.
Cheers
Posted: Tue May 05, 2020 9:43 am
by FractalMotion
Hello guys
I already tried to update to the 2020 version a few times and everytime it just makes my C4D freeze on the loading image GUI , i was in the middle of some projects i didnt bother to update
but right now i would like to enjoy the new update , i did some research on the forums but sill can't find the proper solution to enjoy this new version . Does anyone else is in my case ?
Windows 10 Home 64-bit
Intel Core i7 6700K @ 4.00GHz
RAM 32.0GB Dual-Channel
NVIDIA GeForce GTX 1080
Cinema 4D R20.059
Nvidia studio driver 442.92
Any help appreciated , Have a great day
Cheers
Posted: Tue May 05, 2020 9:58 am
by aoktar
FractalMotion wrote:Hello guys
Cinema 4D R20.059
Cheers
What you mean? I didn't understand where it freezes!
Posted: Tue May 05, 2020 10:55 am
by FractalMotion
Hey Aoktar , Sorry if i was not clear it's totally frozen on the loading GUI no matter the time i'm waiting for it to launch the app.
Posted: Tue May 05, 2020 11:34 am
by aoktar
FractalMotion wrote:Hey Aoktar , Sorry if i was not clear it's totally frozen on the loading GUI no matter the time i'm waiting for it to launch the app.
are you using 2020.1-R2? There was a wrong build for R20 and fixed on latest.
Posted: Tue May 05, 2020 3:01 pm
by Despot
Cannot use this release in R18.057, application hangs on exit even if I haven't invoked the Octane render window.
If I do invoke the render window, when I close it , the plug-in crashes.
