Page 2 of 2
Re: OctaneRender 2023.1.3.0|OctaneSolaris - RC10
Posted: Tue Jun 25, 2024 10:40 am
by adrianr
We're seeing some discrepancies in animation for shots rendered locally vs exported to orbx (Out of Solaris) and rendered on RNDR. In this case we have a rotating object, and the rotation doesn't quite line up (it's not a frame offset issue). Can you reproduce this your side?
Posted: Tue Jun 25, 2024 9:45 pm
by BK
adrianr wrote:We're seeing some discrepancies in animation for shots rendered locally vs exported to orbx (Out of Solaris) and rendered on RNDR. In this case we have a rotating object, and the rotation doesn't quite line up (it's not a frame offset issue). Can you reproduce this your side?
Hi Adrian, thank you for the post.
Would you please let us know if you are using the default Houdini scene scale Unit (meter) or modified as cms?
cheers
Posted: Wed Jul 10, 2024 9:59 am
by galleon27
OK so its been a month since 2023.1.3.1 main plugin has been released. When do you guys plan to release the Solaris plugin?
Also perspective correction is missing from universal camera.
Posted: Mon Jul 15, 2024 3:39 am
by BK
galleon27 wrote:OK so its been a month since 2023.1.3.1 main plugin has been released. When do you guys plan to release the Solaris plugin?
Hi galleon27,
Thank you so much for the reminder.
We will do a release sometime this week if everything goes well..
Oh thanks for reporting the missing Perspective correction.. We have created an internal ticket.
Hope this option can be included in the new release.
Cheers
Posted: Tue Jul 16, 2024 9:01 am
by seriawp
Did you know that Light Pass Mask does not work with Directional Light?
But it works correctly with regular Area Light.
Here I created a post where I described this error
viewtopic.php?f=140&t=83510&p=434398#p434398
Posted: Wed Jul 17, 2024 5:36 am
by BK
seriawp wrote:Did you know that Light Pass Mask does not work with Directional Light?
Thanks, seriawp, for the reminder.
We can replicate this issue.
We hope to get it fixed asap!!
cheers
