Page 2 of 2
Re: Dept of Field noise
Posted: Wed Nov 02, 2022 6:19 pm
by jayroth2020
I recommend that you blur the HDRI, especially given how you are choosing to use it. High frequency details in the image can contribute to noise. Blurring the image can reduce those artifacts, yet still give you the illumination you prefer. Affinity Photo is a good (and free) option here...
Posted: Wed Nov 02, 2022 7:05 pm
by almsdesign
jayroth2020 wrote:I recommend that you blur the HDRI, especially given how you are choosing to use it. High frequency details in the image can contribute to noise. Blurring the image can reduce those artifacts, yet still give you the illumination you prefer. Affinity Photo is a good (and free) option here...
Thank you for the answer, I've tried to blur hdri and also remove it to check if it is a source of the problem, but noise is still here. I don't know, is it possible to share the project file? Maybe I'm missing something :(
Posted: Thu Nov 03, 2022 2:33 pm
by boxfx
Just to throw in my 2 cents, can I ask where this image is going to be used? I ask, because I would consider the amount of noise in the image to be below the level you would get from a real world photograph.
If this is a frame from an animation, then this grain level is far below the level that h264 video encoding will capture
If this image is for print, then the grain is below what most print processes will be able to resolve.
If this is for screen, then jpg compression will remove most of this noise.
As for removing it, make use of the adaptive sampling preview. when rendering to the live view, click the "noise" tab on the bottom of the window to show a green and grey image. Green areas are parts of the image that octane is no longer rendering because it considers them clean enough. Grey areas are still being rendered to improve their quality. If your DOF areas are green, then that means octane gave up rendering them because it considers them clean enough adding more samples wont do anything because the rendering in this area stopped already. If this is the case, you need to lower your noise threshold to make octane resume rendering these ares. Your adaptive noise threshold is currently 0.03 which is a very high quality. To make it even higher, drop this to 0.02 or 0.01.
ps. I find 4x4 "group pixels" tends to give better results overall, ive yet to find a case where the other 2 options are faster or higher quality.
Posted: Thu Nov 03, 2022 2:59 pm
by almsdesign
boxfx wrote:Just to throw in my 2 cents, can I ask where this image is going to be used? I ask, because I would consider the amount of noise in the image to be below the level you would get from a real world photograph.
Thank you for your answer :)
This is will be just an animation, maybe this noise really will not be visible in the final video. Also thanks for the tips about adaptive sampling, I have already tried different values, between 0.01 and 0.04, and nothing :( I changed a min samples, and also tried 4x4 and 2x2. Adaptive sampling gives me a great result in most scenes, but in this case, only with blur from depth of field it changes nothing.
Maybe this is not a problem at all, I just wanted to understand where such noise comes from and how to avoid it in the future
