Page 2 of 2
Re: Solo an Octane node in the viewer like in C4D
Posted: Sat Feb 04, 2023 9:55 am
by Dingbat
oh wow i didn't know about this either - this is a huge addition!
no more messing around with re routing textures to a temporary diffuse material
thank you - this will save a lot of time
OOI, how long has this been there??
Posted: Sun Feb 05, 2023 10:21 pm
by face_off
It's been there for 12 months. Always worth reading the release notes
Posted: Mon Feb 06, 2023 2:19 pm
by Dingbat
i do check them
somehow i missed it
i have a request - it seems i have to deactivate/reactivate 'Solo' each time i select a different texture? or am i using it wrong?
if that is the expected behaviour would it be possible to keep Solo active so that if i change texture the render updates?
Posted: Mon Feb 06, 2023 11:11 pm
by face_off
This is probably doable, but not the indented functionality, and may break other users workflows. If everyone wants it to work this way, happy to see if it can be changed.
Posted: Mon Feb 13, 2023 12:23 pm
by Dingbat
sounds fair
any takers?
Posted: Mon Feb 13, 2023 10:45 pm
by rubberchicken
I’m ok with either option.
Posted: Thu Feb 16, 2023 6:42 pm
by Dingbat
thinking about this a bit more, if it's a case of one or the other, then i think the current behaviour is best
that way you can select a particular node to view, and then you can work on the node itself or any node that comes before, and the render will update
if it's possible to add my request as an additional option (e.g. a checkbox) then great, otherwise i think it creates more problems than it solves
thanks Paul - it probably doesn't get said enough but i really appreciate the plugin and the work you do to maintain it
Posted: Thu Feb 16, 2023 11:44 pm
by face_off
Sounds good!
