Page 2 of 5
Re: Cinema4D version 2020.1.2 (Latest stable)11.06.2020
Posted: Fri Jun 12, 2020 8:38 pm
by aoktar
thanulee wrote:
aoktar wrote: It's stable enough for me, but only problem with previews when you have texture compressions. Of course, it depends to hardware/driver combinations.
Thanks Ahmet. What is this problem that u describe? When we set texture to "float" for example?
Cheers
I talk about this parameter.
Posted: Sat Jun 13, 2020 5:10 am
by eyeonestudio
Cheers
Just Report : Can not Rendering Volume(VDB), TFD, Fume(VDB) - Win10 / Driver 445.98 / TitanXp
Posted: Sat Jun 13, 2020 6:11 am
by bepeg4d
3dworks wrote:
SRCOBB wrote:Is this latest version no longer going to work on my OSX High Sierra?
My 2010 Mac Pro is stuck at OSX 10.13.6, and the Nvidia driver is 387.10.10.10.40.130. Any system updates make my Nvidia cards unusable.
Octane has worked for me up until now. I can't get the 2020.1.2 standalone to open, and C4D won't open with the plugin installed.
Have I hit the wall?
same here, macpro mid 2010 with geforce GTX 1080. release 2019 worked like a charm, but this one crashes at startup as a plugin in cinema, but also as slaves and standalone. crash log is this:
Process:               CINEMA 4D [883]
Path:                  /Production/*/CINEMA 4D.app/Contents/MacOS/CINEMA 4D
Identifier:            net.maxon.cinema4d
Version:               20.1 (0)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           CINEMA 4D [883]
User ID:               501
Date/Time:             2020-06-12 20:32:21.345 +0200
OS Version:            Mac OS X 10.13.6 (17G13035)
Report Version:        12
Anonymous UUID:        B841C2F9-C67E-C61A-949C-585831F2E43B
Time Awake Since Boot: 200 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Illegal instruction: 4
Termination Reason:    Namespace SIGNAL, Code 0x4
Terminating Process:   exc handler [0]
Application Specific Information:
/Users/3dworks/Library/Preferences/MAXON/C4D20_studio_63FEB824/plugins/c4doctane/liboctane.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   liboctane.dylib               	0x000000011fb41ec2 0x11def6000 + 29671106
1   dyld                          	0x000000010949aac6 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 420
2   dyld                          	0x000000010949acf6 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
3   dyld                          	0x0000000109496218 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 330
4   dyld                          	0x00000001094961ab ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, char const*, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 221
5   dyld                          	0x000000010949534e ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 134
6   dyld                          	0x00000001094953e2 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 74
7   dyld                          	0x00000001094893e5 dyld::runInitializers(ImageLoader*) + 82
8   dyld                          	0x00000001094920a8 dlopen + 527
9   libdyld.dylib                 	0x00007fff79755d86 dlopen + 86
10  net.maxon.cinema4d            	0x00000001079e1f0d 0x107883000 + 1437453
11  net.maxon.cinema4d            	0x00000001079e29c4 0x107883000 + 1440196
12  net.maxon.cinema4d            	0x0000000107a09035 0x107883000 + 1597493
13  net.maxon.cinema4d            	0x0000000107a08e6c 0x107883000 + 1597036
14  net.maxon.cinema4d            	0x0000000107a0b115 0x107883000 + 1605909
15  net.maxon.cinema4d            	0x00000001078894f3 0x107883000 + 25843
16  net.maxon.cinema4d            	0x000000010788947c 0x107883000 + 25724
17  libdyld.dylib                 	0x00007fff79754015 start + 1
I think that the issue is not in High Sierra, but in the old CPU, and AVX instructions.
2020.1.x is working correctly here in 2x machines with High Sierra, but the oldest is from 2014.
The core developer team is already investigating the issue.
ciao Beppe
Posted: Sat Jun 13, 2020 6:54 am
by bepeg4d
Everything is working as expected here with 2020.1.2 and TFD:
Should be something else, please, share more info.
ciao Beppe
Posted: Sat Jun 13, 2020 10:29 am
by eyeonestudio
The attachment D9A65DFC-A846-4512-AFDE-D769B2E692DC.jpeg is no longer available
ciao Beppe
TFD FFX is Ok. sorry about that.
But not VDB File. How to render old version VDB files?
I have some vdb assets.
VDB file format compatibility https://groups.google.com/d/msg/openvdb ... vnxNNTCgAJ
222 (OpenVDB 1.0) - First official release of OpenVDB (roughly)
223 (OpenVDB 3.0) - Blosc Compression and Point Index Grids
224 (OpenVDB 3.3/4.0) - Point Data Grids
Posted: Sat Jun 13, 2020 10:57 am
by bepeg4d
Weird, but surely an issue with general SDK, not plugin.
Btw, the following vdb file is from 2015, how old is your vdb file?
ciao Beppe
Posted: Sat Jun 13, 2020 11:17 am
by eyeonestudio
bepeg4d wrote:Weird, but surely an issue with general SDK, not plugin.
ciao Beppe
TESTED : The files below cannot be rendered.
PixelLAB Clouds Smoke https://www.thepixellab.net/vdb-smoke-pack-volume-1
EmberGEN Samples https://jangafx.com/software/embergen/d ... nimations/
Bunny is maybe OpenVDB 1.0(very old)
This issue seems to be specific to OpenVDB 3.0 files. Please maintain compatibility.
Posted: Sat Jun 13, 2020 11:19 am
by aoktar
ciao Beppe
This is quote from SDK and Standalone topic. Not sure about internal changes and compatibility. This is not about plugin side, asked in to team.
Enforce loading VDB files just up to the version currently supported (223).
Posted: Sun Jun 14, 2020 5:33 pm
by fatrobotsneedlove
I cant figure out how to get Cryptomatte working. Currently the Object node puts out an all green pass with outlines and the material node does 2 colors that aren't the same material.
Posted: Mon Jun 15, 2020 8:34 am
by bepeg4d
fatrobotsneedlove wrote:I cant figure out how to get Cryptomatte working. Currently the Object node puts out an all green pass with outlines and the material node does 2 colors that aren't the same material.
Please, make sure that Live View is in LDR-8bit mode, anyway, the results from Picture Viewer should be correct.
ciao Beppe
