Page 2 of 4
Re: C4D crashing without warning after sending render to PV
Posted: Mon Jun 01, 2020 7:20 pm
by aoktar
FH wrote:aoktar wrote:give a try and also use 2020.1-R6
Ok will do. Can you show me where that command is ?
Posted: Mon Jun 01, 2020 8:01 pm
by FH
I'm still getting crashes after emptying cache and installing 2020.1 r6.
Posted: Mon Jun 01, 2020 8:03 pm
by FH
Crashes happen even when juste sending to LV, and always occur during materials loading.
Posted: Mon Jun 01, 2020 8:07 pm
by FH
[2020-06-01 16:02:21][1] generate material:M_1asd0f1a6s0d16w016[2020-06-01 16:02:22][1] OCT:the following error occurred while reading a binary blob: failed load data array
This showed in the last crash.
Posted: Mon Jun 01, 2020 8:46 pm
by aoktar
FH wrote:[2020-06-01 16:02:21][1] generate material:M_1asd0f1a6s0d16w016[2020-06-01 16:02:22][1] OCT:the following error occurred while reading a binary blob: failed load data array
The command I pointed that should solve this issue. Other than this delete prefs folder of c4d and try again.
Posted: Tue Jun 02, 2020 5:01 pm
by FH
I've tried all of the above, but while looking at the octane log, I found this :
[2020-06-02 12:51:47][0] Scene created in plugin version 4050001
[2020-06-02 12:51:47][0] Scene plugin version is older than version:2020.1-R6
Should I copy all my scene and paste it in a new template ?
Posted: Tue Jun 02, 2020 5:21 pm
by jayroth2020
@FH, please attach a scene that causes your issue to occur so we can take a look at it.
Posted: Tue Jun 02, 2020 5:35 pm
by FH
jayroth2020 wrote:@FH, please attach a scene that causes your issue to occur so we can take a look at it.
Here. I can't open the scene now, would crash right away.
Posted: Tue Jun 02, 2020 5:43 pm
by jayroth2020
Thanks, did you say that this file was originally created in v4?
Posted: Tue Jun 02, 2020 5:51 pm
by FH
Yes, it was because I created a template for C4D when I was running on v4.
I removed my template, create a new scene, and copy paste the scene in the blank new scene so it'll fix that problem.
I have opened a previous version for my scene, before everything went crazy crashing. I also de an reinstalled octane plugins and standalone. I haven't encountered any issue for now.
