Page 2 of 18
				Re: Version 4.0-RC7 (Latest release candidate) 24.10.2018
				Posted: Thu Oct 25, 2018 7:24 am
				by VVG
				Hi, Aoktar
explain to me why in standalone render denoised b pass saves file much faster than in cinema4d?
thanks
UPD
and
when will we see?
Planetary environment (
from XB1
				Posted: Thu Oct 25, 2018 9:40 am
				by VVG
				spline render problem/ limitation?
				Posted: Thu Oct 25, 2018 10:21 am
				by aoktar
				VVG wrote:Hi, Aoktar
UPD
and
when will we see?
from XB1
I'm always having user requests or long todo by me and you'll see when I find time to implement that. Sorry!
				Posted: Thu Oct 25, 2018 10:27 am
				by aoktar
				VVG wrote:spline render problem/ limitation?
I cannot know right now. But you can try to tweak the end points to avoid problems. Or "close spline=unchecked" and add some extra points will fix that.
				Posted: Thu Oct 25, 2018 11:00 am
				by vipvip
				thanks a lot for your good Job
AFAIK this RC7 seems to be much stable, i just got en CUDA 700 error when switching a lot between cuda device to render, on a very basic scene, but i switched a lot, just to test
				Posted: Thu Oct 25, 2018 1:57 pm
				by Guy_frog
				aoktar wrote:It could not be better on timing. I'm silently and currently working on a convert function for mix to blend, plus octane to sub_material will be natural part of this. Thanks for the appreciation!
Hi Ahmet, Thank you for taking the time to answer me. It's great to know that you are working on it right now. I'm already salivating at the thought of tasting this!
Good job sir.
				Posted: Thu Oct 25, 2018 2:01 pm
				by aoktar
				Guy_frog wrote:aoktar wrote:It could not be better on timing. I'm silently and currently working on a convert function for mix to blend, plus octane to sub_material will be natural part of this. Thanks for the appreciation!
Good job sir.
Here's proof of work
 https://vimeo.com/297071603
				Posted: Thu Oct 25, 2018 2:47 pm
				by VVG
				aoktar wrote:VVG wrote:spline render problem/ limitation?
i found
after explode segments command  -  render ok
Is this an octane problem / limit?
i tested in 3.08.05 R3 (i think in v4 the same)
				Posted: Thu Oct 25, 2018 3:04 pm
				by teeshiiddo
				Is it possible to save de-noised beauty pass instead of main beauty pass like standalone?
				Posted: Thu Oct 25, 2018 3:39 pm
				by aoktar
				VVG wrote:
i found
Have no time for investigating atm. Sorry!
