Page 2 of 4
				Re: Cannot install the octane demo for rhino 6
				Posted: Sat Nov 24, 2018 8:04 am
				by Micha3D
				Same problem here. And the workaround helps to manual load the plugin and set it as renderer.
Other problem:
* fresh opened Rhino and I draw a box and render it - anything is fine
* now open a new empty file - milimeter small objects
* an error popup and all viewports stay black
* Rhino needs to restart
				Posted: Sat Nov 24, 2018 10:39 am
				by face_off
				Other problem:
Can you give me the exact set of keystrokes you are using to get this error pls?
				Posted: Sat Nov 24, 2018 11:48 am
				by Micha3D
				I seems to happen if a new file opened, independent which file was opened before. I press the "_New" button and than I choose "Small Objects - Millimeters" and press the open button -> error message.
				Posted: Sat Nov 24, 2018 9:55 pm
				by face_off
I cannot reproduce this error, and you have not provided the exact set of keystrokes I requested, so it is difficult to help you on this issue.
				Posted: Sun Nov 25, 2018 11:12 am
				by Micha3D
				Sorry, I don't used any other button than I described, so I don't understand what you are missing. I pressed three buttons per mouse, what should I write more?
I did some more test and found, the Octane UI needs to be opened before. So, maybe this steps help:
* Start Rhino
* open the Octane panel (my panel at the right is open and I need to press the Octane symbol to show the options only)
* open new file per Rhino menu
* -> error
				Posted: Sun Nov 25, 2018 10:46 pm
				by face_off
* Start Rhino
* -> error
I am still not getting this error.  Perhaps your default rendertarget settings are corrupt?  Try deleting C:\Users\[username]\AppData\Local\OctaneRender for Rhinoceros\Defaults\rendertarget.xml.
Also, which version of Rhino and the plugin are you using please?
				Posted: Mon Nov 26, 2018 7:50 am
				by Micha3D
				I deleted the xml file and opened Rhino, switched to Octane and opened a new file. Anything was fine. I opened a new file again and got the error message again. After some click later my computer complete freeze and needs to restart. I restarted and tried again, I get the error message and the black Rhino screen again. No complete freeze now.
I use Rhino 6.10.18311.20531 and Octane 4.00.0.101
My driver is 391.35 because it is the last recommended driver for Octane:
viewtopic.php?f=11&t=68554&p=344376#p344376
				Posted: Mon Nov 26, 2018 8:17 am
				by face_off
I File-New'd 20 times and did not get the error.  Do you get it only if Resolution Lock is enabled?  Can you post a screenshot of your plugin configuration settings please?
				Posted: Mon Nov 26, 2018 9:28 am
				by Micha3D
				Now I found that my Octane version wasn't updated to ...101, but after geting the update to run, the black screen problem stays, only without error message anymore.
I disabled all non Rhino plugins and restarted, but it doesn't help. I disabled at the film settings the "lock aspect ratio" but it doesn't help. Or did you mean an other setting?
				Posted: Mon Nov 26, 2018 9:34 am
				by face_off
Black screen is usually caused by the resolution being set to 2 x 2.  Try changing it.
