Page 2 of 2
Re: Octane no longer works and wont upgrade
Posted: Sat Apr 28, 2018 3:32 am
by wutronic
I tried because it was there? Probably when I was trying to install it initially a while ago, which likely was what was causing problems earlier.
Well, I started totally fresh, formatted windows, and reinstalled cinema 4d R19 (twice, once even fresh trial straight from maxon installer page and updated the install to latest) and still no luck. It is in the correct folder now, but only half loads... (like in the screen shots)
Posted: Sat Apr 28, 2018 9:23 am
by wutronic
is there a better channel to ask this on? I have been trying to fix this for several weeks now with no solution and still am paying for it... ready to jump onto a new render engine at this point :/
Posted: Sun Apr 29, 2018 10:17 pm
by aoktar
wutronic wrote:I tried because it was there? Probably when I was trying to install it initially a while ago, which likely was what was causing problems earlier.
Have you installed under to Cinema4D/plugins/c4doctane directory? Be sure there's not another installation of octane like as you do in "C:\Users\[user name]\AppData\Roaming\MAXON\CINEMA 4D R18_62A5E681\plugins\c4doctane"
Posted: Mon Apr 30, 2018 9:17 am
by wutronic
yeah, like I mentioned, I literally formatted my entire computer to start from absolute zero, even installed the installer straight from Maxon's webpage to make sure I didn't have some weird older version.
Did a search of the Files to make sure they didn't make it back somewhere weird, but the "Roaming" directory was from my last attempt. I have since formatted and started completely over. I am however on windows 10 now, that is the only difference.
I have installed and updated all my drivers to make sure they are current and Cinema is also updated as well as latest version of Octane from the website, I even tried a version that was older, had the same problem where it half loads.
Is there a folder or file that logs the errors that I can get some more info on what might be happening? It is clearly trying to load, but doesn't seem to get all the way.
Posted: Mon Apr 30, 2018 9:21 am
by aoktar
I can check it by a remote connect if you wish. Just PM me.
