Page 2 of 2
Re: Sketchup > standalone > proxies?
Posted: Thu Aug 31, 2017 6:13 am
by Jorgensen
Hi beppe
Ok. Thanks I will try that.
Jorgensen
Posted: Thu Aug 31, 2017 8:58 pm
by Jorgensen
Hi beppe
ah ok, that works fine.
- i export from from sketcup via extensions > octane > export to .ocs / .orbx
- i then import test.ocs into sketchup
- and i double click the ocs node
- and now i can replace object's as i like
but is it possible to update the model from sketchup, without having to import again?
thanks
jorgensen
Posted: Fri Sep 01, 2017 6:07 am
by bepeg4d
Hi jorgensen,
in the Node inspector of the geometry node, you can load a new file, or reload the same if updated:
Happy Rendering,
ciao beppe
Posted: Fri Sep 01, 2017 7:27 am
by Phantom107
Updating instances can be faster, take a look here:
viewtopic.php?f=73&t=57252
Then look for 'Load instances'. With this you can simply press ALT+1 in Octane and it will simply refresh all scatter nodes (but im not sure this shortcut was by default, I might've set that up somewhere)
Posted: Fri Sep 01, 2017 12:06 pm
by Jorgensen
hi beppe
sorry, i was not clear enough in my question.
if i have a house, where i add some objects - like chairs.... i can then export the model from skechup and import the model into the standalone.
here i can doubleclick the imported node, and in here i can relink the chair_dummy to a high quality octane model.
but... if i move the chairs or add some more chairs - how do i then update this (skatter info?) onto the standalone?
i know i can export / import again, but that removes any changes made to the dummies.
thanks
jorgensen
Posted: Fri Sep 01, 2017 12:38 pm
by bepeg4d
Hi jorgensen,
then you can copy paste the content of the updated scatter node, from Sketchup plugin to Standalone.
ciao beppe
