Page 2 of 2
Re: How to do SSS on Max ?!
Posted: Wed Jun 28, 2017 1:31 pm
by paride4331
Hi Fabrice,
you have to set density in scattering node.
Here un basic sss material made with diffuse material.
Posted: Wed Jun 28, 2017 3:54 pm
by Fabrice
Thanks Paride!
It's much simpler with a diffuse mat than with a spec mat
Posted: Thu Jun 29, 2017 8:01 am
by Fabrice
I'm still playing with density but it has allmost no effects.
From 1 to 150 I barely see no changes...
The light should be massively changing to the corner because of the thickness varying...
PS : And another topic, how to make slight reflection on that ?
Posted: Thu Jun 29, 2017 9:41 am
by paride4331
Hi Fabrice,
You should not miss light and transmission.
About the reflection, you may use a material mix, if it can be enough, otherwise you have to use a specular material.
