Page 2 of 2
Re: Slow performance?
Posted: Tue Mar 28, 2017 2:20 pm
by juanjgon
Hmm, the problem related to the freeze after aborting a render should be fixed in the Octane test4 API. Is there anything special in these scenes, like a composite background or something like that?
Posted: Tue Mar 28, 2017 3:02 pm
by Builtdown
I´m using Octane 3.05.
To me it seems that the l-o-n-g abort time is mainly when I have a composite background. Also the long finalizing time at the end of the rendering.
Posted: Tue Apr 04, 2017 4:26 pm
by Builtdown
This is pretty ridiculous.
I have a scene that I rendered in 5k resolution. It has a coomposited background. Rendering took about an hour. But from 99% to final render, it took also about an hour to finalize the render.
After 15 minutes of waiting I would have liked to abort task, but then I would have to re-render the scene...
Posted: Tue Apr 04, 2017 9:09 pm
by juanjgon
And are you sure that if you remove the background or any other LW compositing functions the render works fine? I've found that the render can be a bit slower if the compositing functions are enabled, but I can't understand the final delay of about 1 hour!
Posted: Wed Apr 05, 2017 12:58 pm
by Builtdown
It might have helped when I un-tagged one GPU to "use for tonemap".
I have three GTX1070 cards and now only one is "used for tonemap".
Do you think it might have helped with the Composited BG slowness?
Posted: Wed Apr 05, 2017 2:30 pm
by juanjgon
Perhaps with this option disable on some GPUs less compositing operations are needed.
Posted: Wed Apr 19, 2017 3:06 pm
by juanjgon
For the next build (that I'll release in few days), I've added an option to disable the preview image while rendering using F9/F10. This should improve the rendering performance of scenes with large render resolutions or with the LW compositing functions enabled. Please test it with your scenes to see how it works.
