Page 2 of 3
Re: Max freezes with Octane sun and texture
Posted: Sat Oct 08, 2016 11:14 am
by mark0spasic
paride4331 wrote:Hi mark0spasic,
What about low-priority in device tab?
It`s not related to low or high priority of the graphic cards, I even tried to deselect cards and tested one by one.
Definitely some problem with rgb image inside environment either in Octane sun or regular environment tab.
So max freezes for about 5 mins after that it become unfrozeen but the moment I change any parameter in rgb image (gamma, power etc.) max freezes again for 5 mins.
I must say this happens unrelated to image (hdr) inside rgb image because freeze even without any image loaded in rgb image.
EDIT
Ok so I tested all versions of Octane to see where this bug appears for first time and concluded that last working version is OctaneRender® for 3ds max® v3.03.2 - 4.10, from OctaneRender® for 3ds max® v3.03.2 - 4.11 - OctaneRender® for 3ds max® v3.03.4 - 4.20 [TEST] there is a bug. :roll: :cry:
Posted: Mon Oct 10, 2016 3:31 pm
by paride4331
Hi mark0spasic,
I will try to explain your issue to 3ds Max Octane developers,
even though I was not able to replicate the case.
Thanks for your contribution.
Posted: Thu Oct 20, 2016 2:15 am
by abowen1
hello mark0spasic and octane team . i also am seeing this bug. it happens when i load hdri or exr or jpg into sun texture and instance drag into material editor.
this is not a card priority issue in my testing
and it def was not happening in previous builds
im using OctaneRender_for_3ds_Max_3.03.4_-_4.21
Posted: Thu Oct 20, 2016 3:47 am
by abowen1
here is a sample scene with a jpg instead of hdr (same bug seen with jpg)
andre
Posted: Thu Oct 20, 2016 12:00 pm
by paride4331
Hi abowen1,
I tested your files, it seems to work.
I video recorded about the test and attached it.
I do not think the issue depends on Octane,
It could be quite a latency caused by something else in windows ..?
Posted: Thu Oct 20, 2016 6:52 pm
by abowen1
this is something with octane i am sure . as it wasnt there before and system hasnt changed ... i think you forgot the attachment :-) can u please resend ...and i will continue to look into issue here
A
Posted: Thu Oct 20, 2016 8:33 pm
by abowen1
updated the drivers to latest versions and still experiencing the issue with the software freezing if i select the material slot with the hdri sun texture instance (or copy). is there anything you can suggest ?
mark0spacic have you by chance resolved this issue? :-)
... Also as has been said by mark0spacic . the issue is not seen in OctaneRender® for 3ds max® v3.03.2 - 4.10 only in newer builds :-(
Posted: Fri Oct 21, 2016 7:11 am
by paride4331
Hi abowen1,
I'm sorry, I forgot the attachment.
Here for you.
I will continue to look about your issue.
Posted: Wed Oct 26, 2016 6:44 pm
by mark0spasic
Sorry for not answering earlier in OctaneRender® for 3ds max® v3.03.4 - 4.21 I still have this problem, when I open your test scene my max freezes after I click on material editor. :cry:
Posted: Sat Oct 29, 2016 9:53 am
by mark0spasic
Problem is still present in OctaneRender® for 3ds max® v3.03.4 - 4.22 [TEST] .
