Page 2 of 2
Re: Smoke Simulation / VDB support: How does it work?
Posted: Wed Sep 14, 2016 10:01 pm
by JimStar
grimm wrote:Thanks, I did try that but the absorption input pin would not accept the RGBSpectrum node's output.
It always worked...
You can either substract color:
or use it directly ("Invert absorption" option):
BTW, will release 10.5 soon today with a fix of your animation problem...
Posted: Wed Sep 14, 2016 11:40 pm
by grimm
Awesome, thanks Jimstar, I was probably using the wrong node. I will test tonight. :)
Posted: Thu Sep 15, 2016 2:12 pm
by regionfive
Hi Jimstar,
I found the invert check to affect the smoke in a strange way, making it somehow darker. does it also invert the saturation?
Posted: Sat Sep 17, 2016 6:34 am
by grimm
With the plugin fixed for animation I created a quick video of the smoke, and changed the color. :)
https://vimeo.com/183091945
Jason
Posted: Thu Oct 27, 2016 11:46 pm
by nehale
grimm wrote:Here is what I have so far, just a quick test with a simple scene.
stats:
scale: 100
step len: 0.5
absorption: 0.3
scattering: 0.3
volume properties from the object data tab:
iso: 1
absorption scale: 500
scatter scale: 500
I should add that I let it render to 500 samp/px.
Do you mind sharing this scene file?
Posted: Thu Nov 17, 2016 4:37 am
by kraken
Is there any way to get VOLUMETRIC FOG to work?
Posted: Thu Nov 17, 2016 4:55 am
by Saramary
Posted: Thu Nov 17, 2016 8:15 am
by Smaker1
Hello,
Sorry to hijack this forum as I don't use the plug-in :-) After looking for a not expensive solution to generate smoke simulation I installed Blender yesterday.
I followed a tutorial to generate smoke and baked/exported (vdb format) to Octane stand alone : after some tries and error, it worked and I must say that Blender is not so difficult I was thinking ! That give me new possibilities to improve my renders.
But with "fire" and exactly the same process : imported object doesn' t render in Octane (default volume medium material) and with fire + smoke: it seems that I only have the smoke.
Can someone confirm it or tell me what I'm doing wrong ?
Thanks for your help
Posted: Thu Dec 29, 2016 5:02 pm
by regionfive
Smaker1 wrote:Hello,
Hi Smaker,
JimStar said some time ago, that the vdb attributes in blender are somewhat different than usual and it is not yet completely implemented the right way.
If this is still the case I don't know. So, for now only smoke no fire from blender :)
Posted: Thu Dec 29, 2016 5:39 pm
by pegot
regionfive wrote:JimStar said some time ago, that the vdb attributes in blender are somewhat different than usual and it is not yet completely implemented the right way.
According to JimStar in the below post this situation is now considerably improved:
viewtopic.php?f=23&t=57487&p=299174#p299172
