Page 2 of 2
Re: Was anyone able to create fire, smoke, clouds?
Posted: Tue May 31, 2016 12:20 pm
by boris
Jim
would be nice to have some options in Octane Volume Object for loading a vdb animation:
- frame offset
- playback: play once, loop or pingpong
or is there a way to already do that?
tnx
Posted: Tue May 31, 2016 3:34 pm
by boris
godrays... ok this takes longer to render.
volume medium mapped to octane sun, 10 minutes rendertime, some noise reduction in lightroom
Posted: Tue May 31, 2016 5:34 pm
by coilbook
boris wrote:godrays... ok this takes longer to render.
very nice. I wish e-on Ozone 6 worked with octane it had any clouds you want, haze, fog, smog what ever but it was slow.
Please otoy create a cloud generator where you see clouds all the way to horizon.
Posted: Fri Jun 03, 2016 7:57 pm
by visionmaster2
Could anyone share a 3dsmax file (2015/2016) with a simple exemple of godrays ?
i tryed some tutorials, like this one https://www.youtube.com/watch?v=mGQI5_gjgzs, but impossible to reproduce the effect !
thank you
M.°
Posted: Fri Jun 03, 2016 8:27 pm
by ThaRaven
never tried godrays before. but seems to work
in the volume medium use "Phase + Schlick" and set it high like 0.8 or 0.9
hope it helps
https://www.dropbox.com/s/jy9h8nx97qm54 ... 6.max?dl=0
Posted: Fri Jun 03, 2016 10:14 pm
by visionmaster2
it's help a lot !
thanks a lot ThaRaven !
Posted: Sat Jun 04, 2016 2:02 am
by JimStar
boris wrote:Jim
- frame offset
Yes sure, these features will be implemented in ongoing versions.
After a current versions become rock solid (no new bug reports) - I'll start adding a new features (and new instability together with them)... But we must get a rock solid version before that - 'cause you'll always find some new features you need, so if we will be always implementing them non-stop, there will never be any rock solid versions...;)
Currently I see only one critical issue still left - some slower interactivity when using Forest Pack objects in 3.14. Plus not very stable current 3.X Octane rendering core itself... Other than that - I hope the plugin will be ready for a new features soon...
Posted: Sat Jun 04, 2016 2:23 am
by coilbook
Could someone enplane what is Phase and Schlick. Especially what is Schlick?
I dont see much difference when changing their values.
Posted: Tue Jun 07, 2016 8:54 am
by boris
JimStar wrote:
boris wrote:Jim
- frame offset
probably a good strategy. i appreciate that.
