Page 2 of 2
Re: Backplate Image
Posted: Wed Jun 15, 2016 1:17 am
by azen
We are in the process of putting together an extended FAQ for the 3ds Max plugin. We are currently working with all third-party plugin developers to unify all documentation under a single standard. Solutions from the forum (like this one) will be collated into this FAQ.
Re: Backplate Image
Posted: Mon Sep 05, 2016 3:42 am
by jeffpatton
Sorry to bring up an older thread but it's about the only one I could find on the topic. I followed the instructions here and this seems to only work in the OctaneRender viewport. The actual rendered output image still saves with a black background, not with the backplate.
Is there a way to have it actually save a rendered image as it appears in the OctaneRender viewport (scene lit by HDR but on a photo backplate)?
I see the new backplate, reflections, refractions options in the texture environment map & similar options on the Octane daylight. However all that seems to apply spherical mapping instead of the screen mapping I'm needing for this.
Hopefully I'm just overlooking something obvious.
Re: Backplate Image
Posted: Sat Feb 18, 2017 12:48 am
by senorpablo
Any update on this?
I'm running into the same issue as Jeffpatton, and it seems like a practical request. The framebuffer does not save out the background image. Also, I have an issue which would prevent manual compositing, in that pre-multiplied edges are using the environment as the background color, rather than the backplate image. This results in artifacts.
Re: Backplate Image
Posted: Sat Feb 18, 2017 9:57 am
by paride4331
Hi paulforgy,
try to look at this:
viewtopic.php?f=9&t=59392&p=304010#p304010
Re: Backplate Image
Posted: Wed Feb 22, 2017 5:49 am
by senorpablo
paride4331 wrote:Hi paulforgy,
I was able to get that to work, thanks!
I wish it were more elegant and intuitive.
